Anant #5
Anant #5
Anant #5
Ron Smith
>I saw a post by a guy who had bought this plane and he liked it. I was intrigued, and ordered one a month ago. It was $46.00 delivered. Undaunted by the admonition printed boldly on the box . . "For Industrial Use Only" I just ripped it right open to see what I had. Whoa! . . I was impressed (What do I know) good machining, fit-and-finish . . smooth and clean. I put a Starret rule to it and the sole looked good. Checked the frog (square and true) torqued all the screws and sharpened the too-thin iron. Mounted the already nicely fitting cap-iron and set the plane. Took a 4 foot piece of 2 X 4 and used a spoke shave to carve some impressive divots along its length. With the #5 set coarse 20 stokes had it smooth and straight. Re-set to a fine cut and I had .0015 shaving ! ! . . full width and more-or-less full length. I am impressed ! ! . . .At nine bucks a pound this is the best deal I have found. In fairness I must say my longest plane before was a #4. I had made all the doors (thousands it seems) out of edge-jointed 1 X 4s, some 45 inches tall and 24 inches wide . .and with no battens, frames, or other support. It took a lot of effort to true them with a #4. With this #5 my 4 foot board was true enough to edge glue in 15 20 stokes. I would say a 'factory' sawn 1 X 4 would be ready in three or four passes.
Next, I want a #7 . . and won't be spending 400 bucks on a LN.
Twenty-two inches is a LONG plane . . and flatness of the sole is a major consideration. I'll let you know how that goes. But at $125 for BOTH planes you will probably hear no complaints. Especially since these babies are "For Industrial Use Only"
Re: Anant #5
Re: Anant #5
rusty plane
>I bought Anant's 10 1/2 plane from Highland Hardware about two months ago. I also found that the fit and finish was excellent for the price. After honing the blade I was taking "fluffy" shavings from Cherry here in the shop.
Re: Anant #5
Re: Anant #5
Rossmoor Galoot
>I too have had good luck with Anant planes. I have a smoother and their knock off of the venerable Stanley 78 (the Anant has two arms). With proper tuning they work well and the price is truly unbeatable. I have staunchly defended them on this and other forums but beware, there are others who will pillage your good name for even mentioning Anants as worth fussing with.
Re: Anant #5
Another happy customer
John, NY
>I too own the Anant 10 1/2 and am reasonably impressed. Excellent value for money, very functional, but it isn't a LN!
Have you managed to remove the blade without removing the chip-breaker first?
Re: Anant #5
Re: Anant #5
>I am glad to hear of your good luck with the Anant. After reading reports of problems with them in the past, I shied away from buying any. Perhaps they made an effort to get their quality control in order? Maybe HH insisted upon it?
Now if you want a really bad far-eastern plane, you should try the $4.87 USD Chinese plane that I bought on a whim.
(just think, I could give four of them to someone for the WC Secret Santa gift exchange!)
Re: Anant #5
Re: Anant #5
Skip in Falls Church
>I sort of suspect quality control problems in the past as well. I got an A10 and it seems to be well made even if the casting is a bit light. The sole wasn't dead flat - but it was reasonably flat and didn't take much work to get it as flat as I like. I had to adjust the cap iron a bit and the blade is a bit thin but it seems to work well enough any way.
They're not in the LV or LN class - OTOH they seem to be competively priced with the period Stanley planes you can get off eBay. However, it would seem they would need a lot less work than an eBay Stanley. Of course I would think that the addition of a heavier blade would be beneficial - but the same could be said of an eBay Stanley.
Skip
