Concave Shave
Concave Shave
Concave Shave
John
>Now that the new Veritas concave spokeshave has been out for several weeks, has anyone purchased one...and what do you think it.
Thanks in advance.
John
Re: Concave Shave
Re: Concave Shave
Mike in Mystic
>I have one, and all I can say is that it sure looks pretty :)
I bit the bullet and bought the set of 3 while they were on sale - great deal, IMO. I really just have had a need for the flat shave to this point, and that has performed wonderfully. The concave shave has the same fit and finish, and I fiddled with it a very slight bit (took a few swipes on some dowels). I was able to get shavings without any fuss. I'm planning to take a windsor chair class, and I anticipate that shave will be very helpful in shaping the many spindles. I'm also planning on some kayak paddles sometime in the next months and except similar utility from it.
Mike
Re: Concave Shave
Jim in Burlington Ont.
Re: Concave Shave
Jim in Burlington Ontario
>I have had it for a few weeks and really like that the throat is more open than the other shaves so you can hogg off lumber at a good clip. I wish there was a smaller model to just make chair spindles.
Re: Concave Shave
Re: Concave Shave
John, NY
>Yes, I have one and was using it last weekend to shape the leading edge of the centerboard for my boat. Nothing too strenuous for its first time out the box since the CB is just cedar. I found it did the job very well but as expected was a complete bitch to sharpen. I ended up using an old felt polishing wheel on my buffer cut almost to the right shape and going through a series of compounds. Worked okay, produced a shiney edge good enough to slice a piece of cheese ;) Don't know how else i'd sharpen it...
Re: Concave Shave
Re: Concave Shave
>I clamped the blade between 2 pieces of wood then clamped them into the vise and used micro abrasive paper glued to a dowel.
Re: Concave Shave
Re: Concave Shave
John K in Hastings, MN
>I received mine and looked at it. IIRC, you can sharpen with a 3 1/8" disk with a sandpaper edge. I plan to turn something to size on the lathe.
Nice set of three, though.
John
Re: Concave Shave
Re: Concave Shave
John, NY
>Do you taper the disk so that you have the same honing angle all around the bevel? The problem I find with using something large wrapped in abrasive paper is that when I have the angle correct for the micro-bevel on one side i'm effectively blunting the other... or do you use a microbevel??? On something the size of my gouges I can do it a little at a time but on something with this radius of curvature...
