Winding Sticks
Winding Sticks
Winding Sticks
Brian in Merritt BC
>Okay everyone, I have just gone out and bought some rosewood to make some really fancy Winding Sticks. Planed the things down to final dimensions and am now looking for ideas. I have looked at the one from David Charlseworth (spelling?) and Rob Cosman (www.robcosman.com) and have some ideas for a contrasting wood. My thought is to run a dado along the top of the back stick and place a strip of Maple or Birch in there to act as a contrasting wood. Another idea is to cut a diagonal dado into the corners and of the back one and add maple there instead. I do like the center location finder that Rob has used. So there it is, any ideas or pictures would be great. I will post the final project once I have it finished and of course also several pictures as I am making them.
Thanks
Brian
Re: Winding Sticks
Dunbar's radical solution
Christopher Schwarz
>I messed with a number of designs for winding sticks until I saw the ones that Mike Dunbar uses. They immediately became my favorite.
He uses aluminum angle from Home Depot or Lowe's or whatever. Cut it to whatever length you want (mine are 36"-long each). Spray paint one black and one white. You're done.
The genius of this design is that they *never* go out of true. And because they rest on your work on two spots (forming a triangle) you can use them easily on curved surfaces.
I love traditional tools, but these have proven better than my wooden ones.
Chris
Re: Winding Sticks
Re: Dunbar's radical solution
Bob Hackett
>They also fit together one inside the other so they only take up alittle more space in your box than one would.
MB
Re: Winding Sticks
Showing my ignorance here..
Gary in Vancouver, BC
>I understand the concept of using winding sticks, kind of. Maybe it's my method of work. When taking a rough board to dimenish I first lay it on a flat surface and check for high spots by rocking the corners to determine which corners on the undersurface need to be handplaned down. Once the board no longer rocks, I run it through the thickness planer. Would the winding sticks be used to check the top surface for handplaning instead of running it through the thickness planer?
Re: Winding Sticks
Keep it simple
David Miller from Iowa
>I'm just some guy from Iowa, but a couple reasonably straight sticks ought to do it unless the lighting is bad:)
Re: Winding Sticks
An even simpler guy from Arkansas
Christopher Schwarz
>Maybe I'm not following the thread correctly David, but getting "reasonably straight sticks" is a challenge. I find it simplest to use something that's dirt cheap and never ever needs truing.
Or maybe you're referring to the processes in the intial post. I can't tell. If so, sorry.
Chris
Re: Winding Sticks
Re: An even simpler guy from Arkansas
Brian in Merritt BC
>I have read and I have used Dunbar's approach to winding sticks before. I just love the look and feel of real wood and since I went out and bought some rather expensive Rosewood for this project, I thought some of you might have an idea as to a good design. I want to make something a little more inspirational than the couple of painted extruded aluminium strips even if these are extremley functional.
As for what they are used for Gary, to check for a board that is twisted. I am dimensioning boards by hand and I too make sure that the board does not rock from side to side or front to back, but then I flip the thing over and surface the other side of the board. Then you check for twist and that becomes your reference surface for all other operations. I too use those tailed devices from time to time, but I find the quiet and physical demands of traditional woodworking very appealing to me. If you are interested in learning more, send me an email and I will send some pictures to you.
Anyone interested in this style of woodworking would be very wise to get a copy of Rob Cosman's video (or DVD) from Rough to Ready. I learned a ton of new techniques from this one episode. I am not affiliated, but Rob is my Canadian Plane "pusher" and I am his "Junkie!"
Brian
Re: Winding Sticks
No...
Scott Burr Ben Lomond,CA
>The winding sticks make sure your putting a flat handplaned board thru the planer. Your forgetting about the ever slight twist (and concave, convex visuals too) curverture along the board also.
Re: Winding Sticks
I'll talk for Bill H. here...
>This is an excellent jod for old 3' leveles...
Cheap too.
Re: Winding Sticks
Jim in Burlington Ont.
Jim in Burlington Ontario
>The man's talkin rosewood with maybe something nice for inlay and you come up with aluminum angle iron. I pretty much fell off my seat laughing. I'm still laughin I can see pulling out the angle iron. I like the divided top ones and think that if you can find scraps of Corian to install they seem to be the brightest white substance and you can handplane it nicely.
Re: Winding Sticks
>Reviewing the thread, the intended use of the winding sticks was never stated. One cannot evaluate the efficacy of a tool outside the context of its use.
I presumed (perhaps incorrectly) that their primary use was for evaluating the top of a workbench. If that is not the intended use, my remarks are withdrawn.
If, however, that is indeed the reason for using winding sticks, my personal standard for having a "dead flat" workbench top is for assembly. Frankly, the limitations of my mediocre skill in making the piece far outweigh the downside of having a bench that is a few thousandths off because my winding sticks were not extruded from a factory at tight tolerances.
The use of the sticks stipulate the degree of precison needed. I'm just not skilled to the piont that the variation that meter bar quality winding sticks are the limiting factor in my work, but I do I envy those who reach that level.
Let's not let the tools get ahead of what we are trying to accomplish.
David
PS - fire away at this inadvertant hijack of Brian's legitimate post
Re: Winding Sticks
Beat me to it
>Mine are actually 2 foot, garage sale wonders at $1 for one and free for the other. One even came painted black. I recently, just for ducks, knocked out the (not) level vials, so no one could confuse them with levels.
They're ugly, and those who like pretty tools would be fully justified in making rosewood winding sticks with maple/holly/something else bright inlays, but they do get the job done.
Re: Winding Sticks
More bottom feeding thoughts
>Before I tripped over the two levels, I had purchased, also at a garage sale, an assemble-it-yourself aluminum picture frame, four rather complex extrusions to capture the picture, glass, etc., and be clipped together at the corners.
There's lots of very straight aluminum extrusions out there - the trick is to get past seeing stuff as what the factory thought it was, and instead ask "what can I do with this?"
But again, Brian, I want to emphasize that my choice to go with cheap, fast, and functional is not better than your choice to go with elegant pretty, and historically more accurate. It's a matter of what brings you pleasure.
Re: Winding Sticks
Hey Brian
Dan Clermont in Burnaby
>Hi Brian great seeing you at the woodshow ;ast weekend.
I too like the Rob Cosman winding sticks and built a similar set a couple of years ago.
I used straight grain maple and dropped in some cocobolo inlays on one set. They work real well and it does help to taper them just as Rob says on his website.
He's a Great Canadian plane "Pusher" and I too am his tool "junkie"
Take Care and Stop by sometime for Coffee,
Dan Clermont
Re: Winding Sticks
Re: More bottom feeding thoughts
Patrick Gibbons, Houston, TX
>Older sources I have read suggest using mahogany with an inlay for contrast. The mahogany is used because of stability. Living here in rainy, wet Houston I think the Dunbar solution of aluminum angle is brilliant. Thin strips of wood curl up into a moustache here in no time.
Re: Winding Sticks
Not just for benches
>Winding sticks are definitely handy for spotting twist in a bench top, but that is only one application. You can use them on any board that you intend to flatten, to see where the high spots are and how twisted they really are.
Whether you are using an electron-gobbling jointer or a #7, it's good to know the location and amount of material you need to remove. Often, you will find that it is more than you thought, and that flattening the entire board will mean that you can't get the thickness you need out of the board.
Winding sticks can be very accurate if you really need that degree of accuracy, as in spotting a 1/16" twist over the length of a benchtop, but often they are only needed to get a rougher idea of the lay of the land. Once you get close to final flatness, proper use of your jointer or jointer plane should take care of any remaining twist.
Re: Winding Sticks
My Winding Sticks Experience
>Hi David,
Last summer I made a timber-frame-type shed for my wife for her orchids, using mostly 4x4s. They all twisted as they dried in my car port, and for the braces and mortises, etc., to line up, I had to get rid of the twist on some of the surfaces, and make sure that the two adjacent surfaces with the mortises were at 90� to each other.
The boards were 7-10 feet long, and I bought a pair of factory made winding sticks from Highland Hardware (I think). They are some sort of stable resin (phenolic, maybe) with white and black sides. For many adult eyes (mine, anyway), it is hard to focus on something two feet away, and on something ten feet away, at the same time. I found the contrasting colors a BIG help.
I do not know about using them for a little 3-foot board on top of your workbench, I guess that would be easier?
On my list of things to do before the heat death of the universe is to make some nice ones with ebony or cocobolo, etc., like proposed here, and hide the plastic ones!
Re: Winding Sticks
Here is a curious model:
Re: Winding Sticks
Christopher Fitch @ Memphis
>I did something similar except for 3 things:
1) I never heard of Dunbar's solution (hehe)
2) I made mine shorter (18") - Too short!
3) I didn't think of using them in a triangle position, I used them more in a "L" position
I painted one edge white and the other black.
They work on skinny boards.
Re: Winding Sticks
paul womack
Good call!
For those people who have forgotten what "inspirational" means, here's some totally pointless excellence
BugBear
