Hardware question
>I got one of those folding tables from a friend of mine this weekend to use as a pattern for duplication. At the pivot point where two legs cross each other the maker of the original must of used some type of special hardware to do this as I can see nothing of it. Only thing I can fiqure is that it must be a double ended wood screw with a nylon bushing. Sound like a piece of hardware any of you have seen/used?
For now I just drilled for a 1/4" bolt which is no big deal as this is my prototype of the duplication. I couldn't take the original apart so I fiqured it best to make a practice copy to get the critical measurements just right. good thing I did, as for what appears to be a simple table is really a complex PITA.
Todd O.
