Basic Sharpening Tutorial
Bob Smalser, Seabeck, WA
>[quote]
Bob,
Could you post a tutorial on how you sharpen? I use waterstones but hate the hassle of trying to keep them flat. I have my grandfather�s oilstones some maybe 50 or 75 years old (just guessing) I �would love to see your thoughts in pictures. [/quote]
Glad to help. I don�t use waterstones, but I did spend years using composite stones that also hollowed badly. There are a couple basic techniques you can use to minimize the hollowing. The first is to use the entire surface of both sides of the stone wherever you can�. not just the center�and the other is to do more on the grinder and less on the stone.
Using the entire stone sometimes means you have to forego some jigs, but it�s always good to develop your ability to sharpen freehand as I can think of dozens of situations in even hobby woodworking where your bench and jig won�t be available. All the grandiose words written in the last couple decades on honing, all the expensive gizmos for sale to help you do it, and all the trouble folks seem to have with it puzzle me some. Grind that blade correctly, and the difference in cutting speeds and technique between oil, water or composite stones is meaningless because there isn�t enough honing to be done to measure a difference. Moreover, why would I want to trade my hundred-dollar Taiwanese large pedestal grinder for a much-slower, several-hundred-dollar Tormek?
So I�ll go you one better on your question. I�ll convert an old abused, 2-dollar half-inch firmer chisel to a small skew for lathe work. Lotsa grinding required here�and on burnable 19th-Century carbon, not burn proof High Speed Steel. Get good enough freehanding on your stones, and it takes no longer to put your best edge on that carbon skew using stones as it does to put an inferior edge on an HSS skew using a grinder.
I mark the bevel I want on the chisel using a bevel gage and carbide scriber�
�and grind off the old edge square to the line. Looking at the squared-up flat I made, the chisel�s old bevel largely remains on the bottom side in the pic, but the flat penetrates to at least the center of the bevel at the point of the skew to leave enough steel there to grind a perfect bevel and edge next. The objective in all sharpening is razor-sharp�but also consuming minimum steel in the process.
I�m using the coarsest grinding material I have�both my coarsest grinding stone and 26-grit sanding disks for the roughing work. The coarser the abrasive, the cooler it cuts and the faster you can do the job without stopping to cool the steel with every stroke. Remember that if you turn that steel blue with the 600 degrees it takes to do it, you�ve ruined its temper and all that blue must be ground off for that steel to hold an edge. Takes two minutes to grind.
Next I grind the 20-degree bevel on both sides of the skew. I use the tool rest and the side of the coarse wheel in the 8�, 1750-rpm buffer-grinder. No jigs, no Tormeks, just that angle gage sitting handy on the grinder stand to show me what 20 degrees looks like when grinding either side�.working all that out with the wheel stopped, of course. Takes 5 minutes, taking a little bit off at a time then dipping the tool in water and examining the cut for any adjustments in my hold required. The closer I get to forming an edge, the easier it is to burn the edge.
Learn to watch the trail of grinding sparks flying off the steel�. their density and quantity tell you precisely how much steel you are taking off and from where�showing you how uniform your resulting bevel will be.
Here�s the ground edge.
Now I take the skew to the coarse novaculite stone fresh from the can of kerosene it lives in and measure what 20 degrees looks like for rough honing. I�ll not use a secondary bevel on this edge but hone a flat 20 degrees on both sides. That stone was my uncles, who built boats professionally from 1930 to 1970�no telling how old it is but it�s just as clean and flat as the day it was ground. It may even have belonged to [i]his[/i] father, a carriage maker.
Having taught a number of young people to sharpen over the decades, the single biggest factor in ease of honing is the height of the stone. Do what you have to do to get it secure and to the level of your belt buckle�higher than your kitchen counters, let alone most workbenches. This gets your elbows up and free from your torso to aid you keeping a consistent angle without any rocker or rounding.
I dip the end of the tool in kerosene and make a few strokes on the stone�then I examine it to see what hold adjustments I need to make. See the flat? I need to drop the angle a tad and apply more pressure to the lower edge of the skew to even up that bevel.
Pressure adjustments are made using the fingers of the left hand while I stroke the tool back and forth using my right. Here I�ve wrapped my fingers around the lower edge side to apply more pressure to that edge than the upper or tip edge.
Now you can see I have an evenly formed bevel. Its not perfect�but as only a couple thousandths at the edge really matter, it doesn�t have to be. Takes only another 5 minutes, and if this were merely a secondary bevel on an existing chisel, it would have taken one minute or less.
With the bevel honed on both sides, I clean, buff and phosphate blue the skew before final honing. Cold blue or machinist�s layout blue applied to your tool before honing will teach you gobs about the effects you are having, as the camera picks up the small details shown better than the naked eye. Especially a 50+-year-old naked eye, and especially flattening your chisel backs�. do the rough work flattening backs �not on your expensive stones�but on your belt sander using 150 grit�just remove the bag and clean out the sawdust first.
Continued�
Re: Basic Sharpening Tutorial
Tutorial Part II
Final honing is done on the fine novaculite stone. I have no earthly idea what grit or microns these or my black novaculite stone are�and don�t especially care. I [i]do[/i] know the black stone, which I use only on the thinnest edges, will sharpen a straight razor or scalpel as well an anything I have ever seen. I also know you can�t judge the coarseness of these stones solely by their color�I have a fine stone darker in color than my coarse stone. Note the darkened kerosene on the stone�how uniform it is compared to the bevel being honed. Ground steel particles cause the color. Just like watching the spark trail while grinding, watching the fresh lube get dirty tells you how even your bevel is forming and where more or less pressure is needed.
An evenly formed and flat, fully honed bevel ready for stropping. Took 2 minutes�about how long it should take you to hone the back and secondary bevel on a bench chisel.
I strop using a stitched muslin wheel loaded with Knifemaker�s Green Rouge�there are many stropping mediums, and it doesn�t matter which one you use. What matters is stropping your bevel at the same angles you used in honing. I also use a hard felt wheel, but it removes more steel and gets very hot very quickly, and I use it primarily to quickly touch up my turning tools without any honing.
If you are stropping at the correct angle yet the tool is duller after you are done, your error is being made at the fine stone, not the strop. When you hone one bevel, you create a wire edge that is honed off when you switch to hone the other side of the chisel. If your hold and angles are inconsistent, that wire edge can be too thick�an edge that should have been removed on the stones rather than the strop, because when the strop removes it, it breaks it off deep enough into the edge to dull the tool.
The secret to long tool life is to take the 5 minutes it takes to touch them up after each day's use, keeping those honing angles constant and dropping the honing angle occasionally to flatten the main bevel as the secondary bevel wears. If you never round or rocker your edge.... you can go literally decades without grinding it again.
The final result shaves dry hair painlessly�
�and the finished skew. Total time including bluing and turning was less than two hours.
Proper sharpening can be done well in many mediums�my counsel is not to buy anything new but learn to use what you have. But I�m not your guy to ask about water stone grits, diamond paste microns, indexing plates or Tormeks�I only lust after the best novaculite stones ever made�Hall�s:
http://www.hallsproedge.com/history.htm
>Great stuff, Bob. For those interested in this recurring subject, I think the new book by Tom Lie-Nielsen on sharpening is outstanding. Lots of pics demo how he sharpens just about anything.
Don't use the side of a grinding wheel - EVER
joel
>I know people do it but it's very very dangerous. Modern grinding wheels are not designed to ever be used on on the side and I have been cautioned against this by more than one maker and professional user. (they do make special grinding wheels for side grinding).
The reason is that as you gind on the side of the stone the stone can heat up and expand only on one side of the wheel. Enough expansion and you get stress that can lead to a crack and a wheel flying apart. A wheel flying apart can kill you. It's not worth the risk.
You can say - well - I'm careful and I don't do it often, and so far everything is fine - but it only takes one failure and frankly considering the potentional for disaster it isn't worth the risk.
This is expecially true with most people's grinders with 60 or 100 grit wheels modern cool wheels. You grinder has a coarser wheel on it but I would say that isn't typical for most people with newer grinders.
Re: Don't use the side of a grinding wheel - EVER
>I certainly agree one shouldn't put a lot of pressure on it....
...but having done it for 40 or so years, I can't agree it's especially dangerous.
joel
>Bob,
you might have the magic touch - but the average person reading your pages may not - and depending on their equipment you never know. It's just not a good way of doing it and something that shouldn't be encouraged.
I was actually trained to sharpen turning tool on the side of the wheel too. But was admonished against it a few years ago for the previously mentioned reasons and now don't. Modern wheels are just different.
And you are grinding (as I was) carbon steel tools. With the modern propensity towards HSS tools (which are the overwhelming choice of most turners) they grind slower, hotter, and longer and there is more risk.
>Noted....I'll add a warning in the final draft.
Re: Side of wheel
Larry Clinton - Frankfort, Indiana
>Don't know Joel, I have done it for many years too, without a problem. Also use the side / edge of my surface grinder wheel without a problem. In our tool room the surface grinders are often profiled on one corner of the face and used to precision grind - wonder why that never causes problems. Biggest danger I have seen is abused wheels - been dropped or otherwise shocked. I always "ring" a wheel before installing it to be sure it doesn't have a hidden crack. (I have seen one disintragrate on a grinder- no one was injured but just luck).
Please......
>let's place the responsibility for using a tool where it belongs; squarely on the tool user. Once you start being responsible for what someone else may or may do there is no end to it.
Agree with your thoughts there, Joel
Andrew F in Australia
>My training too.
Re: Please......
joel
>Certainy but one needs all the information to make an informed decision
Re: Side of wheel
joel
>surface grinder wheels are different chemistry, they are being dowsed with coolant as you grind. And there is a considerable margin of safety in modern wheels. But why get into the habit if you don't have too?
The person who finally convinced me that using the side of the wheel was really dangerous was Barry Iles - who ginds tools for a living. They mostly use big 48" wheels but they also use small wheels for certain things. He has seen wheel failures and frankly I don't what to. But there is another reason. If you use your equipment the way it was designed you can go safer but also a lot, lot faster.
Remember also my comments were to a person writing a manual for instruction for inexperieced people with all sorts of variables at stake. Bob is adding a warning in his instructions which I think is the way to go.
Re: Side of wheel
>I do understand your concern about a manual for new users. However, I do want to clarify some things. First most, including my Boyar Schultz 6 x 12, surface grinders are dry grinders. At work we have about a dozen grinders in the tool room. I believe about 3 are used wet. Others may be capable of operating wet, (all can be but are normally not equipped with the pump & sump system). I am not sure about the "chemistry" of the wheels, but don't think there is a whole lot of difference in the strength or fragility of the binding agents used on most wheels. Again I understand where you are coming from. so please don't take this as a criticism.
Re: Agree with your thoughts there, Joel
Rick Hoppe (Los Angeles)
>I don't have to worry about breaking stones. I use this belt grinder from Lee Valley with the Veritas grinding jig.
It produces a flat grind and only costs $54.50! I couldn't be happier with it.
saw a documentary today----
Gypsydave in alabama
>----some guy in Peru having about a third of a grinding wheel removed from his forhead------went in about 2 inches----he wasn't using the side of the wheel, the large saw blade he was sharpening jammed and fractured the wheel------------seems to me a jam on the side of a wheel could make that happen even easier, but I don't know---anyway--he was lucky---he lived
Re: saw a documentary today----
>One thing is for sure: a Tormek at 90 rpm will not do that!
Low speed hazzards
Bob Hackett
>Most people think low speed+low hazzard.That`s not always the case.
We were replumbing yet another fishing boat and sat to wait while one of the Dulac brothers threaded pipe for us.It was winter in Maine so we all were wearing insulated coveralls over everything else.
Now Duke Dulac was normally as efficent as any of us and we were alittle surprised by how long it was taking him so I voluteered to go see what the holdup was.Seems in an effort to be as efficient as possible Duke put an elbow on one end of the pipe while threading the other in the machine.The wrench became tangled in his coveralls and the low speed machine just kept lifting him free of the floor,spinning him around and smacking him back down.He had lost count of the revolutions by the time I showed up and pulled the plug.I had almost figured out how to untangle him without cutting his coveralls when the rest of the crew showed up.
It didn`t help that his brother thought it would be great fun to see Duke`s new thrill ride for himself and plugged him back in.
Some things can be just as funny the second time around.Too bad Duke didn`t feel the same way about it.
Keep an eye on that Tormek and don`t get too far from that plug.
Mainely,Bob
Re: Low speed hazzards
>Funny Story!
Jack Guzman from Maine
funny indeed
>Thanks for the laugh Bob
Re: funny indeed
>Ho, ho, ho, ha, ha, ha, this is indeed very funny. Amazing the things some Frogs will do for a little attention eh?
I can tell you a story about a fellow named Paul Dulac that dosen't have a funny ending. Paul was night watchman for the lumbermill I worked at. Liked the bottle alot as well, and one night while checking a horizonal wood-waste auger he got his foot tangled in it somehow and bled to death.
Todd O.
