bench top gloat??
bench top gloat??
bench top gloat??
Steven McKinley from Calgary
>I'm not sure if this is a gloat or not. I've been doing some casual labour for a counter top company that is moving. They were throwing out some 1.5" butcher block counter top and I snagged it. Unfortunately none of the pieces are long enough to provide me with a solid one piece work bench top. What I was thinking of doing was joining the pieces with either biscuits or dowels, and then adhering it to two pieces of 3/4" plywood. That would give me 3 inch top. I think mounting it to the plywood would take care of any rigidity problems. Two of the pieces could be joined end to end, and then I would have to cut one of the "slabs" into three pieces, glue them up to make a piece wide enough to match the other two and then glue that one on to the other two in order to get a bench top as long as I want. However, one of the guys at the counter top factory said I may still get some movement even though the joining would be end to end with the long grain (does that make sense??) What do you think, will movement be minimal enough to make this a worthwhile effort?
Steven,
Re: bench top gloat??
David Miller from Iowa
>I built up a bench top in a similar fashion with good results. I didn't take the trouble to dowel the end pieces together, just ran a line of screws from underneath where the edge of the pieces were. The joints moved a little in the first year but after the second flattening it has stayed exactly the same.
Patrick Gibbons
>Sounds dubious to me. Besides why go to that trouble? I have been building single-use units and like having benchtops on them. Take the individual pieces and make a sharpening station where a metalworking vise can be permenantly installed, a mortising bench, a dovetailing bench, the top of a moving tool station, the list goes on.
Patrick Gibbons
>Other stations I forgot to mention; a carving bench, a wood-bending station, a panel-assembly station, a jig station for mitering or jointing. Just send me the tops. I've got a lot of uses for them.
They might be radioactive send to me for proper
Victor Parisian - Houston
>disposal. ;~)
Jim in Burlington Ont.
Jim in Burlington Ontario
>What about ripping the pieces up narrower say 6-12" wide having the guys run them thru the machines to get the glue joint end on them then staggering the joints and reglueing it together? They use glue joints in all the tops that I have seen. That way you could have one solid piece.
Good idea.
