Workbench Planing Stop
Dennis Mcdonaugh
>My planing stop is a piece of 3/4" plywood 4" wide, slightly shorter than the width of my bench. Its held in place by three bolts inserted into the bench through slots which run almost the width of the ply. I can raise the stop from slightly above the top of the bench to almost 3" above the bench. Usually I just raise it half an inch or so above the bench top. Wide boards can be planed right up agains the stop with no problem. I clamp thin boards against a bench dog with the front vice to keep them from moving side to side when planing.
