LV Large Shoulder Plane
Christopher Fitch @ Memphis
>Well I just received my LV Large Shoulder Plane today here at work. I am only able to give it a cursory inspection. I decided to post some of my thoughts right off.
As expected, the plane is well made and looks nice.
I have had the chance to examine and use the LN Large Shoulder Plane. My uncle has one and I have been able to play around with it some. Given this I can provide a somewhat informed comparison between the two.
On paper, one would think that the two planes are quite similar. From LN's site we find that the stats on their plane are:
Length = 8 1/4"
Width = 1 1/4"
Weight = 4 lbs
Bedding angle: 18 degrees
Blade bevel angle: 25 degrees
Effective cutting angle: 43 degrees
Blade stats: A2 Steel, RC 60-62, .154" thick
The LV Plane is:
Length = 8 1/4"
Width = 1 1/4"
Weight = 3.75 lbs
Bedding angle: 15 degrees
Effective cutting angle: 40 degrees
Blade stats: A2 Steel, RC 60-62, .125" thick
When I used the LN plane, two things jumped out:
1) it FEELs heavy...and a bit awkward
2) it's not easy to hold..
My uncle made similar comments. He has used his plane alot recently since he has been building a second house and building furniture for it. One of his complaints is that the plane is tiring to use over an extended period of time.
In contrast, the Lee valley plane does not seem to feel the same way, at least for me. I find it to be much easier to hold and more comfortable. What makes that more amazing is that it weighs about the same as the LN plane, but due to its design, it does not seem to suffer the same problems. In addition, the knobs help with holding the plane. Of course if a user finds that the knobs are problematic, they can easily be removed (or replaced with the brass knobs)
Well that's my initial thoughts...
