Installing bandsaw tires
Michael Kieta-near Ramstein, Germany
>Hello everyone,
Yes I know this is the wrong side for this question, but I've posted this over "there" too. I know many of you have Neanderbuddies, so....I have an old Delta/Milwaukee 14 inch bandsaw. I want to replace the old tires which are hard and have splits in them. I've purchased new tires from Highland Hardware. The article I've seen in FWW makes the process of replacing the tires look very complicated, such as using a die grinder with a custom rest to true and crown the tires.
I'm concerned because the bandsaw works "fairly well" as it is. The blade comes off the wheels more frequently than it should, but it will usually track and cuts 1-2" stock fairly well. Am I excessively concerned about a simple task, or am I better off leaving well enough as is....
Thanks in advance for any suggestions, links, references, etc.
Michael in currently sunny Germany
