Flattening Water Stones
Tom Wolf
>Hi All,
I enjoyed the conversation earlier on the waterstone/oilstone/diamond stone systems earlier. Very informative.
One question I have for all of you waterstone users is how you flatten your stones. I'm planning on purchasing either the norton or shapton system but don't want to purchase a diamond plate or the flattening plate shapton offers. I learned to flatten waterstones using the 110 grit ceramic block with titaniam on the surface and liked it OK.
Anyone know if this is adequate to flatten the harder shapton stones or maybe the lee valley psa laminate with silicone carbide lapping material on plate glass might work? Any advise would be appreciated.
Thanks,
Tom Wolf
Re: Flattening Water Stones
Bruce, a MN galoot
>Try drywall sanding screen. Works good. Relatively cheap.
Bruce
Re: Flattening Water Stones - cheap!
CONGER - The Irish diaspora in Munich
>The drywall is cheap.
I went to my local stone mason (I live near several 'up-market'(?) graveyards) and the mason was glad to have me take some off-cuts of granite and marble from his skip (saved him money!). These are great and 'solid as a rock'... and when they wear out(?) there are more where they came from.
To mis-quote Brendan Behan - 'there are people dying nowadays, who could never have afforded to before'.
-g-
Victor Parisian - Houston
>Ok, the discussion is flattening waterstones. I've been rubbing mine against each other under running water with some success. What are the rest of you doing? Techniques that are quick and effective please.
Victor - Sitting in Houston early in the morning thinking we ducked Ivan again and wanting to go to the shop for a few minutes before I run out the door to work.
Rossmoor Galoot
>Victor,
I was taught your method also and use it for normal stone maintenance. I lately found, however, that my coarser stones were slightly dished and flattened them using drywall screen on top of sandpaper. It was quick and easy albeit messy. I still think I'll use the stones against each other normally and the drywall screen method when necessary.
Two-stone Troubles
Christopher Schwarz
>The problem with rubbing two stones together to true them is there's no guarantee that you've greated two flat surfaces. One could be concave and the other one sypathetically convex. It will seem like they are true, but they are not.
You either need three stones so you can test them against one another, or you need a flat reference surface. Float glass, DMT, grainte plate, cast iron, whatever. And you need an abrasive: wet/dry sandpaper, the DMT etc.
Chris
Re: Two-stone Troubles
>Thanks for the replys Guys.
How about a large scrap of MDF and 220 grit sanding paper held in place with a mist of water? I have both on hand. Do you see any problem with this? I reason that if the Mdf gets soaked and starts to get rough I can turn it over for one more use and after that throw it away (where it was going anyway).
DMT?? I should know this. Not senior enough for senior moments, more like a brain f*rt.
Victor (Just goofing off. Now back to the work.)
Tony - Memphis
>I flattened my Nortons for the first time recently. I just used sandpaper on glass with water. Went amazingly quick and easy.
Tony
steve knight
>if you do it right you can do it. but you can't just rub them together. you need to use one always to flatten only. you need to use the middle of the stone more then the ends. so you turn it sideways and work the higher parts of the stone you sharpen with. this is how most of the japanese flatten their stones. it works fine but you need to know how to do it.
steve knight
>you can flatten a shapton stone with drywall screen but you only get about one flattening per sheet. they are so hard that you really need another method to flatten them. Here i was using the other brand of stones and I finally deside to get the sanding screen. well as soon as I get it from ebay I find the shapton stones and it is useless (G)
>Rubbing two waterstones together reminds me too much of the method we used to make lenses for telescopes in astronomy club when I was a kid. Real easy to make one convex and the other concave. (the hard part was to make the curve parabolic)
