Rob Lee - drill bit help?
Gary from Vancouver, BC
>Rob I need your help. I believe LV carried the drill bits as shown below at one time (long ago) Much to my frustration, I have been unable to source the manufacturer or a supplier to buy some of these. The bits are only marked HSS and the diameter size. Do you know who made them or where I might be able to buy some?
I truly like them, they have wide flutes for chip clearance and bore a wonderfully clean hole.
My apologies in advance to anyone flustered at my liberties in posting a non-handtool topic on this board. Please indulge me, since I do contribute on occasion and know that the folks here have helped on numerous topics.
Re: Rob Lee - drill bit help?
>Those would fit just fine in a breast drill - so this qualifies as a hand tool topic too.
Bob Hackett
>Those look like split point parabolic bits.You should be able to pick them up from any well stocked machine tool supplier.MSC would be a good place to start.The ones I own are cobalt.
Mainely,Bob
OK...Drill bit test...
Scott Burr Ben Lomond,CA
>I have a set of German ones, I think... The bits are ground at 96 deg instead of the typical 118 deg espasally for WW or for similar "soft and easily terrible materials";).
Rob Lee
>Hi Gary -
Indeed, they are a parabolic flute bit, as mentioned in another post...
Last address we have (with phone and fax #'s) has been sent by email...
Cheers -
Rob
>Thank you Rob. I'll contact the vendor and possibly get back to you on the odd sizes you still have in stock. I have a business trip until Friday, so I'll reach you then. Thank you very much, once again.
