OT: Anyone Here Work with Rawhide?
Bob Hutchins in central Texas
>SWMBO makes me walk with her and the dog most ever' day. I found a sapling of unknown species in a pile of brush, delimbed, debarked and dried it and use it as a walking stick. I finally settled on a length that suits me (54" or 137.5 cm) and decided that it needs a hand grip. I wrapped it with rawhide stripping (the same kind used as bootlaces), but I can't seem to get it tight enough to keep from slipping. Either the rawhide stretches in use or the diameter of the stick is continuing to shrink after 9 months. The stick is roughly 1-1/4" in diameter at the top and tapers to about 3/4" at the bottom end.
Next, I tried soaking the rawhide and stretching it as I wrapped it around the stick. The problem is that I can't "whip" the wet rawhide (ie, wrap it around a loop of the material so that I can pull the last end under the wrapping to hold it in place). The wrapping is too tight to allow the rawhide loop to slip to pull the final end tight. Would really appreciate any suggestions on how to make the rawhide work.
While I'm at it, how would you make a ferrule on the end to keep it from wearing as it strikes the ground?
Requisite hand tool content: I cut it to length with a Disston, used my drawknife to debark and shape the shaft and my MF egg beater to drill a hold for a wrist loop. Oh, and my Nicholson #49 to shape the end to fit my thumb.
TIA
BobH
