Do gimlets work? Bradalls?
Roy from Cincy
>I'm trying to get rid of my electric drill, but I still like it for drilling screw holes. I've read about gimlets and bradalls, but I don't know where they would work and not work. Are there any other good choices for drilling screw holes in the neanderly correct way?
Re: Do gimlets work? Bradalls?
Push drill
Bob Hackett
>Smaller that a yankee scewdriver but works the same way.
I use it far more than gimlets or bradawls.Come to think of it,I use it far more than it`s cordless counterpart.
Mainely,Bob
They work fine,Roy
Andrew F in Australia
>But it's still horses for courses.
When I'm mounting hinges or other accurate work, I use a bradawl.
For most work but, I use a cordless/corded drill.
Cheers,
Andrew
Re: Push drill
Tony Z.
>I agree with Bob: I have both gimlets and a pushdrill. I reach for the pushdrill first, second and third. Much quicker and easier.
Jack Guzman from Maine
>I never use a powered drill in my shop.I do use one all day at work though. For cabinet screws I use a small eggbeater or a push drill.For some in softer woods I'll use a scratch awl with a good sharp tip.---Jack
Alan Hamilton
>Roy,
I use my gimlets all the time. They're handy and they work extremely well in softwoods; they don't work nearly so well in hardwoods. I have an egg beater that I use on hardwoods if there aren't many screws; if there are lots of screws I get out my alternately powered drill.
Alan
Gimlets are often 1st and best option
Angus Barclay, in New Zealand
>For a few small holes, a gimlet is often the best option. You can put at least two or three holes in a piece using a gimlet and hang it back in the tool rack in the same amount of time it takes to just put drillbit in the chuck of a pushdrill or eggbeater. Of course, if you're doing a lot of holes, then various drills start to stack up a bit better in comparison.
I reckon you need - at a minimum - 3 different size gimlets, small and medium eggbeaters and twist-bits to fit, AND 10in and 12in braceS and a set of bits to fit.
regards
Angus Barclay
Brad awl pronunciation OT
Adam Cherubini, NJ
>Andrew,
Can you tell me how folks pronounce "brad awl" in Australia? I've heard English pronunciations, including "brawl" which I thought unbelievable.
Anybody else? Bugbear? Angus?
Adam
Re: Brad awl pronunciation OT
>Here in New Zealand I pronouce that particular tool as:
"brad" - same as the name of a small nail or a character from the Rocky Horror Picture Show
"all" - without any pronunciation of the W in the middle.
I have no idea how Australians pronounce such a word. It may be similar to the way New Zealanders pronounce it, but Australians and New Zealanders are fond of mangling the English language, so it may be very different too.
regards
Angus Barclay
Re: Gimlets are often 1st and best option
Mike G.
>I've got a J S Fray tool handle that I carry in my toolbox at work. It has a gimlet in it along with a chisel and gouge tip. (I don't use the screwdriver bits because of their size...too small, and everything is either phillips, sq. drive, or now they've come out with a torx screw.) I've got another unmarked tool handle that I use sometimes that has a bradawl in it.
Mike G.
Same here - pronounced 'bradall' Thanks Angus
Does anyone sell new brad awls?
Crown tools make one Don
Or more correct pron: "braddle"
