sharpening bench chisels
David E Whiting
>has any tried sharpening bench chisels using just the Wolverine pocket ??
Re: sharpening bench chisels
Bob Hackett
>It works very well for chisels with either rounded or other non-flat faces.I use it for all my large framing chisels by Merrill or Underhill(which are rounded)and Douglas(which are beveled to a central ridge.
Just match the bevel angle to the face of the wheel by moving the arm in or out.Be sure to scribe a line on the back for reference.
Mainely,Bob
Wolverine Pocket?
>Isn't that the whooly-hopper who ya' that is designed for sharpening turning gouges or is this something different?
Todd O.
Re: Wolverine Pocket?
Bob Hackett
>Yep,it is.But we WWers have a reputation for inventiveness that we have to uphold.Besides,it comes with a regular flat rest for grinding the run of the mill stuff.
The Vari-grind is the whiz-bang tool that puts the fancy grinds on things like bowl gouges.I`ve used it to put a fingernail grind on one carving chisel so far.
Mainely,Bob
>Agree with you one the inventivness Bob, and that is why I'd make one. they are simple enough and there has been numerous plans on making them in the WW rags. Could save some body a bunch of $$$ to spend on rust.
Todd O.
Re: Wolverine Homemade Varigrind Jig *LINK*
>Here's the best instructions I know on making your own knock-off Wolverine Varigrind Jig
�quivalent maison de la Vari-Grind and a bunch of other kewl sharpening stuff, with downloadable PDF plans, as well.
