plane blade bevel of 10 deg?
Jack Guzman from Maine
>I cleaned up a #65 I picked up today. It was pretty rough with rust. It didn't have the knuckle joint cap but I have one that came with a broken plane. All cleaned up ok and I assembled it with an old iron I had until I get the original cleaned and sharpened. The iron that came with it was the correct iron but the bevel was ground at 10 deg. I think that I can get it back to a 25 bevel but I'm going to have to shorten it quite a bit.
Any idea why someone would grind a 10 deg bevel on a low angle plane?---Jack
Re: plane blade bevel of 10 deg?
Greg Sloop
>Cutting balsa end grain?
Gone bonkers?
Dunno...
Greg
Dick Darin
>Before you go to 25 deg. try putting a 7 or 8 deg. back bevel on the iron. Try it out and see if the iron will hold a edge. If it doesn't work out only a few minutes work lost and if it does you will have a plane that glides through end grain.
Jorge Casta�eda
>Jack,
I would put a secondary bevel at the desired angle and use it that way until the bevel, with repeated sharpening one day it will be the way you want it, it may take a long time!, so there is no need to grind away good metal.
jorge
Because a 65 is a low angle
Scott Burr Ben Lomond,CA
>plane. It works bevel up (for all that don't know this). A low bevel angle like that is what I've seen in a lot in old Staley planes. It's what I'll call "the carpenter's grind" for lack of a term. Follow me here. You have a low angle block plane and your working doug fir or some other shi*%y soft wood, sorry... let's say "construction grade lumber". You sharpen as you go and all you want are results. Something that will get the job done. It's easier to lower the bevel when sharping "on the go" to get the results needed in the trade (i.e. planning wood of that caliber).
Hence the rust IMHO a carpenters plane, probably road around the back of an old 50's chevy truck (lucky plane). Just start getting the bevel back to where you want it to where you want it to be. Heck it might be a micro bevel a that point, but it sounds like that's what you want. I can't see how you'd end up loosing a lot of bevel (or blade) by brining it back up.
Scott... Who's aquired a Matherson blade that looks like a factory grind at 15 deg iron for my Spires smoother. That will cut thru anything...for the first few strokes anyway...
>I guess I'll just put my desired angle on it and use it as is.Saves me alot of time and metal.For some reason I figured I needed to grind it back to where the bevel starts. Thanks---Jack
