THE WOODRAT IS BACK!
Record plane question
Scott Burr in Ben Lomond CA
>Hi All, I have a newer T5 that is very clean except the front knob has its finish flaking/cracking off.
The shooting handle and tote are pristine.
All the wood is stained then the top coated. Does anyone know what the Record plane company used? It looks a lot like gloss poly, but I'm not sure.
I've removed all the chipped finish and I'm ready to refinish it. I would like to use what they used.
Thanks!
Re: Record plane question
Christopher Fitch @ Memphis
>From what I remember, it's a lacquer...
I have a few older record planes with wood handles (3 of them) and all suffered from a similar problem to varying degrees.
Easiest way that worked for me was to use lacquer thinner to remove enough of the old finish to smooth it out. I had to sand one handle a bit since the wood under the finish had alot of water damage. Then I stuck the eraser end of a pencil in the screw hole from the bottom. Then I dipped the handle in some Deft brushing lacquer to coat it and hung it up to dry. You can repeat if you want a few coats. It varied for me based on the shape of the handle.
You can get fancy by rubbing/buffing the handle a bit after it dries. I did that on my 405 handle and it looks and feels super!
John Horobin
>Its the post war planes that really suffer from the cracked lacquer problem, especially those from the late 1950's and 1960's. The prewar rosewood finish seems to be better. Best to clean off, stain and oil or wax I think.
John
Yes, It's one from the 60's
>Just like me:). It's strange only the front knob has this problem. Look like there was some contamination or the stained wood was wet when they applied the lacquer.
Re: Yes, It's one from the 60's
John Horobin
>Yes, the cost cutting had just set in then with Record planes (well actually the mid 1950's onwards - quite a bit later than with Stanley).
I've even got one or two boxed unused planes from this period where the cracking and flaking is bad - probably due to the wood changing with humidity I think.
John
paul womack
I wouldn't - it's prone to flaking and cracking :-)
BugBear (who strips, sands, stains and danish-oils)
