Making a Spar Plane Inexpensively
Bob Smalser, Seabeck, WA
>James Krenov shows a simple way to make custom wood planes in his book, �The Fine Art of Cabinetmaking�. The only problem for a boatbuilder, who might need a half dozen spar planes of different sizes, is the price of high-quality, aftermarket irons of sufficient thickness for a wood-bodied plane.
There is a less expensive way to a high-quality end, and that is converting old flea-market woodies. Auburn, Ohio Tool, Fulton, and dozens of other 19th-Century manufacturers competed hard with each other in quality and value. These planes are generally beech with thick, tempered cast-steel irons�some of them laminated like today�s Japanese blades�and mild steel cap irons. The ones the collectors don�t want are worn, scruffy and cracked with the logos stamped into the wood illegible�. you see them at swap meets and on Ebay for as little as 5 dollars each. We�ll use the same modern-glue rationale to make permanent repairs as Krenov used in making split-bodied planes. Make sure the one you buy has the original thick iron with some length left in it and not too much pitting on the back side near the edge.
Here�s an old, worn-out Ohio Tool coffin smoother above I�ll remake into a spar plane. I�ve jointed the cracked sole flat, and will laminate a thick, squared-up piece of beech to it. How thick? Thicker than the plane and cap iron assembly will penetrate the jointed sole of the body�.plus a little more for good measure. Also note the rapid technique for marking center lines in the photo.
I laminate using boatbuilder�s epoxy�a coat of unthickened on each faying surface followed by a thickened coat�I worked the unthickened coat into the cracks in the sole using gentle heat for penetration�and used a lead-weighted mallet as a �clamp�. Epoxy doesn�t like a lot of clamping pressure.
I use the same heat technique to repair the many cracks in the plane�s top side�cleaning those cracks with a thin solvent, first like acetone or trichloroethylene to remove any oil. I dye the epoxy to match the wood, merely for cosmetics.
Old woodies like these generally wear much more at the toe than heel, which changes the iron�s angle of attack, so I rip the sole parallel on the table saw.
Now I chop out a new throat from the throat side of the plane. The rear of the throat is a 45-degree angle and the front bevel of the throat needed to clear shavings is about 20 degrees in the opposite direction. I merely index the chisels against the plane body and tap and pare.
I continue to remove wedge-shaped waste until the back of the throat and the front of the throat meet�
�in a nice, clean �V� about halfway to the bottom of my over-thick sole stock. The cleaner and more accurately-indexed your new throat, the cleaner the resulting mouth will be�. which I�ll cut shortly on the table saw.
To lay out the eventual depth of cut of the cove I am about to mill, I measure the depth to the bottom of the �V� and transfer that measurement to the plane body.
Continued�
Re: Making a Spar Plane Inexpensively
Part II
There are two basic ways to lay out a cove cut on the table saw�either by the depth of the cove or the width of the cove, and I�ll show both methods. The resulting radius will always be a segment of a circle and is variable in size from the radius of the table saw blade downward. To lay out the cove by depth, set the saw blade to the desired depth and adjust the parallel ruler until both legs touch the blade. To lay out the cove by width, set the width of the legs first using a rule, and adjust the parallel ruler on the saw table and the height of the blade until the legs touch. The results will be the angle required for the temporary fence, and the depth of the cut.
Also note also the inked tick mark on the red blade insert�.that marks the exact center of the arbor and is used to fine tune the fence, centering the cut by insuring the center line of the plane body passes over the center of the saw blade teeth at the arbor.
Shown is the layout of a rather wide-radius cove I�ll use on this plane�
�for a narrower-radius cove for a small spar, the fence must be positioned at a more acute angle to the saw blade.
How do I get the exact radius and depth required for a specific spar size? Trial and error cutting scrap and testing against an existing spar of the size I desire, that�s how. I�m sure there are more sophisticated ways to lay them out�but it�d probably make my head hurt puzzling them out.
As the cove radius for this plane is wider than the plane body, I cyano on some temporary outriggers to make the cut. A freshly-jointed temporary fence is securely clamped to the saw table at the angle indicated by the parallel ruler. The cuts are made in 1/16th� vertical increments until the desired depth is reached using multiple passes by raising the blade with each succeeding pass.
Beginning at a shallow 1/16th, it is a simple matter to check that the cut is centered and to test the radius against the spar you are trying to duplicate�and adjusting the temporary fence as needed.
Once satisfied with my fence settings, I continue making passes until I reach the desired depth�. the desired depth in this case being a perfectly formed mouth in the sole as shown below.
Now�if you�ve been getting away with bad table saw habits all this time, doing your first cove cut may bring them to light with great surprise and violence:
Insure the saw blade is sharp and true�the more teeth the cleaner the cut�insure your temporary fence is dead straight and the edge square to the table�insure you use a push stick that applies pressure to the toe as well as the heel of the piece�.with added pressure in direction of the fence�and under no circumstances pull the work piece backwards into the saw blade, which will promptly throw it through the wall and perhaps drag your fingers into the blade as it takes off. Remember that the machine can�t hear you cry.
A vertical temporary fence and featherboards can also be rigged (and are a good idea) when coving long stock�but wouldn�t be effective coving a short plane.
Now that I have a mouth, I clean up the applied sole and and scribe the plane iron for grinding.
I rough grind to the scribe line before attempting to regrind the bevel�
�then I reinsert the iron and scribe the bevel from the opposite side. A similar plane blade serves as a model for how I will transition the corners of the bevel.
Then I rough grind the bevel to my marks.
I could have used the grinding wheel, or dressed a grinding wheel to the radius desired�.but I prefer 26-grit heavy abrasive disks mounted to an old wheel with contact cement. A 9� disk mounted to an 8� wheel provides a flexible, forgiving grinding edge, and the coarse disks grind significantly cooler than carborundum wheels. I can do the most of the entire grind without cooling the iron in water.
Continued�
Re: Part III
I finish the rough grind on the bevel using the Dremel with chainsaw grinding stones�
�and do the cap iron using the same techniques.
I like to buff and phosphate blue the steel before final honing�the blue acts as an indicator fluid and the phosphate followed by oil protects from rust.
Final honing of the irons is done with oil stones and round slip stones�but can be done using any sharpening system and abrasive paper wrapped around dowels. A goodly bit of time was spent getting the iron�s back dead flat with coarse and fine stones before honing the bevel with the slip stone.
The cap iron was bent and honed for a tight fit to the flattened back of the plane iron�.I strop the edges on the buffing wheel so I can see them better�and you can see on the left that both it and the plane iron radius need one more slight adjustment, which can be done by hand with the stones.
When I�m satisfied with the iron assembly, I double check it by mounting and setting for a fine cut�then give the plane a test run:
The wide shavings and quality of the resulting surface are the real test.
steve knight
>great job. I had fortten about the tablesaw trick. this is by far the most practial way to make the planes. plus it gives life to a tool that may have gotten chucked.
Re: Part II
paul womack
In a "real" spar plane, the "wear" is also curved resulting in a parallel (and potentially tight) mouth.
The conversion process leads to a mouth that's wider at the edges (see above)
Fortunately, I don't think spar planes have an overwhelming need for a tight mouth.
But, if you were making your "dream spar plane" from scratch, it's one more thing to think about.
BugBear
paul womack
>great job. I had forgotten about the tablesaw trick. this is by far the most practial way to make the planes. plus it gives life to a tool that may have gotten chucked.
Yes - it's nice to find a job for an almost-never-used tablesaw, once you hit the slope.
BugBear
Re: Part II
>Spars are always softwood, so there's more leeway for width.
Re: Part II
Geometrically, this is not true. The only circular arc you can get using this method is the arc of the diameter of the blade itself. All tighter arcs are elliptical. The tighter the radius you need, the more eccentric. This means that the closer the arc gets to the table top, the flatter it gets. The arc is tightest (smallest "radius") at the top, or in this case, in the center of the plane's cutter.
This is not a serioius problem, however. In fact it works in your favor, since it decreases the tendency for the corners of the plane blade to dig in, but it does mean that most of the cutting will be done at the center of the blade, especially for small spars. It also means you don't need several planes to shape a tapered spar :^) For making decorative cove molding, it is a totally insignificant effect.
A trick to minimize the effect is to use a 7 1/4" circular saw blade instead of the 10" table saw blade, or use a 6" dado blade. Don't use a whole stack of dado blades, because that will result in a flat at the top of the curve.
Other than this small nikpicking point, you have produced another valuable (and very timely) article. Thank you for publishing it here.
Yesterday, I got the spar I'm working on to a square state. Al least what is left of the timber I started with I can now lift by myself. Next Wednesday, I'll get it round, starting with the octagon gauge I made from your inspiration. I was just going to make it faceted, with sixteen sides, and then sand off the facets, but now I might try to speed things up a bit with a hollow molding plane, since I don't have time this week to hunt down the raw materials for, and build, a dedicated 3" diameter spar plane. I will file your exposition for future use, just as I have filed most of the others you have given us.
As an aside, I have another point of concern about the tablesaw method of making cove molding. It is not significant for one plane sole, but if you have many feet of molding to run, a table saw is probably not a good tool for doing it. Table saw trunnion bearings are not usually designed for the thrust loads generated by forcing wood sideways against the blade. This abuse can wear out the bearings prematurely. When I'm making molding, I usually hog out the majority of the waste with several cuts on the table saw, just to speed thinks up a bit, and then do the final shaping with hollows, rounds, etc., as needed.
Re: Part II
>Thanks for some excellent feedback....I saved them for a later revision.
Another comment worthy of note is many feel the fence is on the wrong side of the saw blade in my pics. They are also correct. I've done it both ways, and have seen folks lose control and throw workpieces both ways, but the sawing forces pushing the workpiece into rather than away from the fence is the best technique where possible. The downside is that if control is lost, the resulting accident is more spectacular as the blade squeezes the workpiece agaonst the fence before throwing it.
Re: What do you do if...
>...you need to make a plane to round a spar greater than 10" in diameter? :^)
>Use a combo of router followed by "round" and "backing out" planes.
The original spar planes were made with round planes and rasps.
Bob Hackett
>I`ve heard tales and seen pictures of folks making large masts,booms,etc.The one I like best is the pic I saw of a flat belt lathe made from 2 poppets bolted to the dock stringers under a boatshed.It was powered by an old pickup that was blocked in place.The workmen removed one of the tires and the belt rode on the rim.They used a freestanding toolrest to turn the mast and I was shown a skew chisel that was used on the job(5" wide).
The scary part was when Hutch told me they used large sanding belts to sand the mast. seems they just turned them inside out and placed them over the mast after removing a poppet.To sand they just stepped into them,put them aroung thier waist and leaned back sidestepping up and down the mast.I hate to think what would happen if you let the belt get slack and it grabbed with you in it.
Mainely,Bob
>I agree, the belt sanding sounds really scary.
I have some PSA-backed sandpaper in a roll, about 4" wide, that I usually stick to thin strips of sandpaper to make sanding battens. You've given me an idea. I think I'll find something much more flexible that I can put handles on the ends, and stick the paper to the inside of. Anyone have any ideas? Maybe an old web sling that used to be used for lifting small boats, until it got discarded after it got cut, if I can find it? Thanks for the idea.
Jim in Burlington Ont.
Who would of thought
Jim in Burlington Ontario
>Bob you blew me away again. Although I don't think I'll ever build a boat alot of it could be applied to making a compass plane.
A use for old jeans?
>Why not just take a pair of old jeans and cut a strip down the leg, then run a seam down each edge to prevent loose threads? Old denim is so flexible that I would think it would adapt itself well to your turnings.
This assumes, of course, that by the time you're finished with a pair of jeans there's still some cloth left.
I was thinking nylon
Bob Hackett
>Who really uses all that nylon they give you on those ratcheting tie down straps?It` tough,very limber,and cheap.Just melt the ends after you cut.
If you make up something alittle more ridgid,think about putting velcro on it.Industrial Abrasive Supply sells velco backed sheets that are the best I`ve found.I buy the 3 ft wide remnants and cut my own discs using a cookie cutter made from an old hole saw.
Mainely,Bob
