Observation
Dan Donaldson
>My wife wants a small box to put something in and this looked like a good opportunity to try lyptus to see how it worked. I found out one thing for sure; That stuff is HARD! I set out to make some dovetails (not fancy as it is just a utility box) and that is when the fun started. I marked the boards, and sawed the first cuts. When I got out the chisels that I normally use for dovetails (some small bench chisels that I have used in everything from poplar to cherry to maple and oak with no problems) and started chopping. After the first few mallet strikes, the edge folded over like I was hitting concrete. I says to myself, 'self, this ain't going to work", so I got out my two cherries, which proceeded to fold over immediately also. I finally had to take one and sharpen it to a much steeper angle to get it to keep an edge long enough to cut out even one section, and had to rehone after every few strikes.
It is being marketed as a look alike for mahogany, which it kinda does, but I am not sure it is worth the extra tool abuse for that purpose. Not sure how it would be for outdoor use because if it is good for weather, I might consider it for benches or something, but for general furniture, I think I will stick to real mahogany as I am a wimp and it does not look enough like the real thing for me to put up with the aggravation.
I now can feel for our friends down under that have woods that are probably even harder.;-)
(I would be willing to put up with it if it were nicer looking, but there are too many other woods that are just as nice IMHO that are a LOT easier to work. I work sometimes with cocobolo, which is also hard, but it is also pretty ;-)
