Work Knife Replacement
Bob Smalser, Seabeck, WA
I use a knife several times a day on the job that involves a lot of tree work, excavation and heavy construction. Much as I love the automatic Buck, it�s just not tough enough for the job, and I decide to replace it with a fixed blade. So I start looking for rigging knives�short, thick, and tough enough to hit the blade back with a hammer. Put off by the 100-dollar-plus price of the better ones, I looked around for older, used knives to grind down, but couldn�t find one with a thick enough blade. Retired shipwright Dave Fleming was nice enough to go around to marine stores and handle a bunch of them�and recommended the Linder in the 60-dollar range. So I ordered one.
Great knife and perfect for my needs�. but the sheath at top left that came with it wasn�t made for that knife�. way too tight and the knife rides backwards for a right-hander. My usual trick of building up the knife handle with foam and tape, soaking the sheath and letting them dry out while mated didn�t work. The chrome-tanned shoe leather didn�t stretch and mold itself around the knife. Oh well�the sheaths for my Buck and multitool have seen better days, and I recently lost my Maglite sheath�so I�ll simply have to make a new one that accommodates all my usual side arms.
I make a pattern out of graph paper, puzzling out all the tool pockets and seam allowances by trial fitting, snipping and cutting�.
�and when I�m satisfied I won�t ruin any expensive leather, cut the pattern out from vegetable tanned tooling leather, which will stretch and shrink very forgivingly to accommodate my guesses on sizes and seams.
As I�ll carry this all day, every day, I want the tools mounted relatively high on my belt so they don�t gore me sitting in the truck, and I want the sheath to tip forward a bit�so I position the belt slide on the back of the sheath accordingly. I use a pounce wheel to mark the seams for even stitches.
On the front of the sheath I�ll mount my multitool�I lay out an applied pocket�
�and stitch it on with lock stitches using a harness stitcher. I could also use the sewing palm and sail maker�s needle to make lock stitches, but the harness stitcher is easier.
Continued�.
