Another wood plane care question
Steve Kubien
Steve Kubien
>Hi everyone,
Alan B's question got me to thinking about a wooden side bead (I think that's what it is called) plane I recently picked up off the 'bay. The rear piece of boxing is very loose. Regular yellow glue to put it back in or something else?
Also, there are a few cracks which I would like to fill/glue back. Wood filler, epoxy or CA glue to fill them?
One more related question....is CA glue the same thing as "Krazy Glue" or HotStuff from Lee Valley?
Thanks,
Steve Kubien
Ajax, Ontario
remove the _9 to email
P.S. If someone can point me towards a webpage/article on restoring wooden planes I would be very grateful.
Re: Another wood plane care question
Jim in Burlington Ont.
Jim in Burlington Ontario
>I can help you with the CA glue it's both the Krazy glue and the stuff at LV. The thick one is fantastic that LV Sells. I squeeze it out onto the tip of a screwdriver and spread it out then I can scrape it off the screwdriver when it dries.
Bob Smalser, Seabeck, WA
>Don't ever use aliphatic glues on any antique that may need repair again. Awful stuff.
For a user tool - use epoxy....a good boatbuilder's epoxy with thickeners and dyes like West Marine's. It can be glued over when the time comes.
http://www.cianperez.com/Wood/WoodDocs/Wood_How_To/Smalser_on_RehabbingWoodenPlanes.htm
http://media5.hypernet.com/cgi-bin/UBB/ultimatebb.cgi?ubb=get_topic&f=1&t=009010&p=
A turner`s trick
Bob Hackett
>If you hit the cracks with the water thin CA glue first it will wick down to the start of the crack and seal it.Then follow up with either the medium or gap filling immediately after the water thin and the thin will carry the thicker glue deep into the crack.If you want to disguise the crack just lightly sand the area near the crack and fill the crack with the resulting dust(grime and all)and the crack will just about disappear.
Buy the good CA glue from either a woodturning supply house or a RC model shop.Krazy glue isn`t near as good quality as the stuff you`ll find there.
Mainely,Bob
Chad Boehlke
>Hi Iam new to this place. I have been a collect and user of old planes as well as restored then to working use. In the past when I ran across loss parts I have used outdoor wood glue. It holds very well and you dont' see the glue in the craks of the loses parts. I don't fill up holes or craks for it looks better, plus its a wast of time. Some of those cracks are stress craks from the humidity moving the woodfibers, thoses are needed to keep the plane stable. I also wipe the body of the plane down with rubbing alchol and then put boiled linseed oil on it. For any metal part I soak it in vinager for 24 hrs, then use steel wool to clean off the rust and dirt. By doing this I have planes that are clean from dirt and are useable. There is also a book called "Restoring, Tuning & Using Classic Woodworking Tools" by Michael Dunbar. I hope this helps.
