bench redesign how-to
Steve Kubien
>Evening everybody,
My bench top is 3.5" thick, made from construction 2x4's on edge and has a traditional shoulder vise. Lately I have been wishing I had built a deep skirt across the front to use holdfasts while jointing. So, I want to retrofit such a thing. Here is my idea. Tell me what you think of it....
I'll add a 2x10, on edge of course, across the front with holes drilled and spaced for the holdfasts. I was planning to add a 3/4" plywood back to it so it will resist cracking along the grain as the holdfasts are hammered in. The issue is how to attach the 2x10. I could use lag bolts, expansion bolts, biscuits, or a pile of long wood screws (my least favourite option). The 2x10 will be a softwood (probably pine or construction grade spruce) to match the rest of the bench. I should mention that the plywood will extend from the bottom edge of the 2x10 up to the bottom of the bench top (effectively creating a large, wide rabbet.
So, what's way to go about this? I realize that I will have to re-drill the holes for my bench dogs, making them closer to the front of the bench. I had actually been planning to that for a while.
Thanks in advance,
Steve kubien
Ajax, Ontario
remove the _9 to email
