Titebond Glue Query
AD
>Hi all
I have just glued up a benchtop with Titebond II and found the excess glue squeezed out of the joints was still quite tacky 24hrs later. I then re-read the instructions and found that it should not be used below 55 degrees F. I have just moved from a warm climate to a colder climate and have never had to consider temperature before in glue ups. The average temp since glue up (48 hours ago) has been between 45-50 degrees F.
Before I take the clamps off, does anyone have any idea if the glue will in fact set below 55 degrees and if so, any idea how long it would take to set?
Next time, I will read the instructions first!!
Finally, what woodworking glues do any cold climate woodworkers recommend?
regards,
Andrew
