REAL MILK PAINT
A Handled Smoother *LINK*
L. Hanson - N. Idaho
>Hey all!
Just wanted to show off a plane I've recently finished making, made from beech and purpleheart and uses an iron from my great granddad's plane, an old Auburn...
I'm not as happy as I wanted to be with the final finish of it... and my carving skills are still a bit crude (as if you can't tell). But it was so much fun to make that I found I was spending too much time on it and other projects were starting to suffer... so I forced myself to wrap it up. But at least I got it to work pretty good, in any case...
I started a page on my web site if anyone is interested (actually, more like 10 pages...sheesh!). I'll link to it at the bottom. I apologize in advance for the length (if you actually bother to read it!), but like I said, I was having fun!
Thanks for looking!
L. Hanson
www.norsewoodsmith.com
Handled Smoother
Re: A Handled Smoother *LINK*
Charles
>I think your plane looks very good. Your carving talent is pretty good also. It is not up there with carving faces or animals, but who needs that on a plane.
Did you copy the angle for the blade from another plane? Where there any pitfalls you could tell another want to be planemaker?
Steve Kubien
Steve Kubien
>I look forward to browsing your site again to see the write up on this. It looks great and the family history aspect must make it more special.
Nice job and thanks for sharing!
Steve Kubien
Ajax, Ont
Frank Mutchler
>Hi, L. (Lars, Lawrence, ??) Great documentary and exemplary work. Thanks for sharing!!
>Thank you very much!
Sorry for the length -
The angle for the blade on this one is 50 degrees. It's the same angle as I did previously on another plane, whose basic design was gleaned from an old text by Leonard Lee and David Perch, and also from a book on making traditional wooden planes authored by John Whelan - a book I would highly recommend to anybody considering building wooden planes.
There were only a few issues during the whole process I would re-think... the first is using 2 disparate woods such as purpleheart and beech. They don't file or float quite the same, so you you have to be careful when doing an area where you are floating both types - but it wasn't too big of an issue, I just had to be a bit careful. Also, the purpleheart I used was very prone to tear out - but on the plus side it seems very much harder than the beech. I guess only time will tell on how the plane will fare.
Another issue I can think of involved the wedge... I've been using a 12-1/2 degree pitch, and I am starting to think that a shallower angle (like 8 to 10 degrees) would provide a better fit. The Auburn I got the iron from had such an angle. But I would have to experiment further before I could say that with any certainty.
I think I can also see some of the benefits to using a single iron rather than a double... The fit of the iron right at the mouth, the clearing of the shavings, and the wedge might all benefit from it... But there again, I don't have the experience (yet) to comment further. I think the next one I make will use a single iron, though, to test it out.
I can tell you that building it was immensely fun - there is no reason in the world that anybody who is a fan of wooden planes should try to make one. My understanding of the workings of a wooden plane (as simple as it may seem) has grown tremendously since I started making them.
Thanks again!
L. Hanson
norsewoodsmith.com
>The L is for Leif, actually...
Thanks for the reply!
R.J.Whelan
>L ... thoroughly enjoyed you tale of building this plane; it was definitely one of the best photographed and illustrated I've seen - maybe you should write a book ... rj
edit that last....
>"I can tell you that building it was immensely fun - there is no reason in the world that anybody who is a fan of wooden planes should try to make one. "
OOPS - that should read "there is no reason in the world that anybody who is a fan of wooden planes **shouldN'T** try to make one."
Blasted grammar teachers..... ;-)
Sorry for that...
Great Article...
Scott Burr in Ben Lomond CA
>And a nice plane too. I enjoyed it very much. Thank you for taking the time to write up the story.
Scott needing to make a plane someday.
