question for MKII users (Lyn? others?) - long
Mike in Mystic
>Hi everyone,
I have a bit of a dilemma concerning proper technique/usage of the Veritas MKII power sharpener. I've had it for awhile now and love it - my tools have never been so sharp so easily. At any rate, I noticed something a bit bothersome, namely my "micro" bevels were coming out quite deep, sometimes reaching a third to half of the primary bevel.
I knew this to be a not-so-good result, as it was removing too much material, but try as I might to adjust my technique on the MKII it didn't seem to matter. I tried using lightER pressure while sharpening, but in order to achieve a uniform scratch pattern on the bevel, I would sometimes apply a bit more pressure.
For clarity, my method has been to place the tool close to the center of the disk and press down, then move a little more to the edge and repeat. Then I move to the other side of the wheel and repeat again. All the while checking my progress and making sure not to overheat the tool. This seems to work fine, except when I switch to the thinner platters the "micro"bevel very quickly becomes much to deep along the edge.
The grits I've been using are as follows and in this order: 80 grit Zirconia; 120 grit Zirconia; 150 grit Al. Ox.; 220 Al. Ox.; 320 Al. Ox.; 500 Al. Ox.; 1200 Al. Ox.; 5 micron Si.C; 0.5 micron Chromium Oxide. The first four are on the thicker platters and the remainder on the thinner platters.
So, I sent a question off to Lee Valley asking what they would suggest in order to ask what they think I should do differently. Here's there response:
Thank you for your inquiry. We have had a moment to review Mr. Lee�s book and reflect on your sharpening steps. We conclude that the multiple stages of sharpening you have mentioned is removing plenty of material and exposing more face distance on your micro bevel than the micro bevels applied by hand in Mr. Lee�s book.
Instead, the best steel is found at the end of the chisel and excessive mechanical sharpening will reduce the length of the chisel and remove the hardest material at an alarming rate. Given that your tools are very sharp and your technique seems to work, we would respectfully suggest that you reduce the number of stages in your sharpening and use a very light touch. Extensive sharpening can shorten the life of your tools because most blades are not tempered steel for the entire length of the blade.
We would like to list some simple guidelines here that will help you create a very good edge on your chisel while reducing the number of steps (and thereby lengthening the lifespan of your tools).
If your chisels are not in very good shape you should use the coarsest disk to clean up the back and produce the primary bevel. If they are in reasonable shape, use the second coarsest disk instead.
Switch the platter to the second finest sanding paper and polish the back of the chisel. Then polish the primary bevel quickly as well.
Finally, use the thinner platter with the finest paper and create your primary bevel with a light touch.
The existence of an extra long face on your micro bevel can also indicate that your primary bevel was not formed to a complete point before the micro bevel was created. So long as the primary bevel has a uniform slope and is formed to a perfect point, a lightly applied micro bevel should not expose very much face/surface.
We hope this explanation has been helpful and we look forward to hearing from you again.
Sincerely,
Wanda Gibson
Internet Customer Service Representative
So, I wanted to find out:
1) Do you all agree that I should stop using the progression of grits I've been using (btw, I only use the very coarse grits for initial flattening and/or changing primary bevels)?
2) If you say "no" to #1, how are you doing with your MKII and what are your suggestions?
Sorry for the very long post, but I wanted to give a good explanation of all of this so as to be clear about the whole scenario.
Thanks for your help,
Mike
Mystic, CT
