Veritas MkII power sharpener update
Paul M. in San Diego
>A couple of weeks ago, I posted how much I liked this machine. The only drawback I found was I couldn't flatten the backs of wide chisels without rounding the edges. Today I figured out how to flatten backs with this unit.
I have a #7 jointer with a blade that was flattened on a waterstone with a slight dish in it. The end result is a blade where the back is ever so slightly thicker in the middle than the edges. The chip breaker has had problems seating flat on the blade and it frequently jammed with shavings. I've found that once a blade is "humped" this way due to a dished waterstone, that I can't seem to reflatten the blade by hand as the blade always rocks on the hump while moving it across the waterstone.
The secret to flattening blade backs on this unit is to never bring the blade to the spinning wheel. The slightest mistake in presentation angles causes the edges to be ground away very quickly. Instead, start up the motor with the blade already on the wheel, and shut off power before pulling the blade away.
I removed the tool rest to get it out of the way. I put on the finest 9um grit platter, and laid the blade on the wheel so that the business end of the blade is pointing away from the direction of rotation. I pushed down firmly on the blade with two fingers while holding the non-business end of the blade that hangs off the edge of the platter. I found that the startup jerk is not so bad as I turned on power with my other hand.
I got the feel of this at 9um, but realized that this blade needed too much work. I moved up to 20um and finally 40um to get this flat across the front edge before going back down the grits to 9um for finishing. The end result is much better than I've seen with the King 6000 waterstone (which is the finest one I have).
I then sharpened the bevel, which took only a minute or two. I took Lyn's message to heart, and used both sides of the platter equally, and had no problems with out-of-square edges. I also found that this naturally cambers the blade slightly, which is something I prefer.
Re: Veritas MkII power sharpener update
steve knight
>I find it easier to just rest a little bit of the blade farther back on the wheel and then rock it onto full contact. same with removing it. this is easier then tryign to turn the machine on and off while holding a blade.
Jim in Burlington Ont.
Jim in Burlington Ontario
>What about using a foot switch to start and stop the sharpener? They are cheap and I use mine for a few machines.
Lyn J. Mangiameli
>Great report.
I sometimes think about adding a foot switch to the new version as the only thing I really don't like about it is the cheap way they implemented a switch. (The much more expensive NUSS had a nice convenient rubber protected switch on the front of the machine). I have one around here somewhere--just need to find it. Such an arrangement might be useful for what you have described.
Do be VERY careful about loosing control of the blade, and about what direction it might be spun off the platter if you loose your grip on it. It can become quite a projectile and I have scars--fortunately only on the wall--for a few times when a smaller blade like a block plane blade went flying. Doesn't do much for your sharp edge, but could be tragic if that sharp edge decides to cross your path on the way to stopping.
I'm in the early stages of exploring the use of a blade flattening holder that will use a central post to which a side arm will hold the blade. I haven't made the arm yet, for lack of time, but will likely be getting it together in the next couple of months (got a little writing project to complete first before a lynching party is set out my way).
It's wonderful to have a growing body of QPSS users to exchange tips with. I think the potential for the QPSS is much greater than is presently realized.
Paul Kierstead
>I am with Steve on this one; that technique works very well. I learned it through a little trial and error. The lesson I learned the hard way (OK, very hard, did it a few times...) was when you *lift* the blade, you must not lift the back first...*DOH*.
What's QPSS stand for?
Wendell @ Murphy, TX
Re: What's QPSS stand for? *LINK*
>Lyn defined this and other acronyms in a post analyzing the new LV Power Sharpening System and other sharpening systems on the Turning Forum
Re: Sharpening recommendation (very long) *LINK* .
The history of the acronyms
Lyn J. Mangiameli
>I was one of the early adopters of the original Lee Valley Power Sharpening System. The early unit still needed some design refinement, and as folks might expect, I was rather candid in my appraisal of its faults as well as its strenghts.
Among other things, I complained about the racket the machine made, and that I felt it was too easy to stall both the turntable and the optional belt sander. I believe Rob actually coined the acronym NUSS (Noisy, Underpowered, Sharpening System) as a joke, but (perhaps to his own horror) it became more than a private joke in our correspondence but ended up as a standard way it was refered to internally(afterall NUSS is a lot shorter than Lee Valley Power Sharpening System.
When the new MkII version came to pass, it was obviously apparent how much quieter and more powerful the new version was. So I coined the acronym QPSS which was explained in the link William gave (Quite Powerful Sharpening System).
I believe the acronyms accurately capture some principal characteristics distinquishing the two units (though with some design modifications, the original version almost eliminated the stalling)and I continue to use them as a shorthand nomenclature to refer to the individual units.
Re: Quite Powerful or Quiet, Powerful?
Quiet I just didn't proofread
Lyn J. Mangiameli
