Gouge question *LINK*
Asher F.
>Hello everyone.
I am building a glass panel door using a mortise and tennon joint. The profile is relatively simple: the face has round-over inner and outer edge, the back is rabbetted. The glass panel is also sitting in the rabbet.
Because the frame construction is mortise-and-tennon, the inner round edge could be mitered at 45 degrees on rail and style to meet at the corner. This is fine but it may cause a gap in the corner if wood shrinks. To prevent this from happening it�s recommended to use a gouge on one of the sides � a round cut will match the molding on the other side making it look like it�s mitered in the corner.
Since the inner edge is rounded over with a �� radius bit, I obviously need a gouge that cuts �� radius curves.
The dilemma: how do I know what gouge size do I need? If it says ��, does it mean it�s cutting a �� radius or it�s the width of the blade?
Is it worth getting a whole set or just get the one I need for right now?
Thanks in advance for ALL your help!
Asher, F.
Lee Valey gouge set
