Old Tool Chest ( kind of long)
Mike G.
>I have an old tool chest. I used to think it was made of Pine, but now I'm not sure. It was made by the original owner and painted a dark green. Of course, over the years, the paint has been worn off around the edges and corners. After some judicious scraping and a little plane work, I've come to the conclusion that it's possibly made of Chestnut. Has a raised panel lid with saw storage as was typical. The original owner had painted some fancy pin striping with corner scrolls on each side with his initials right under the lock, which is original by the way. It has four sliding tills in it, also. The chest measures about 33" L x 19" D x 14" H. Also, there is a longitudinal crack right next to the raised panel of the lid.
I'd like to put this old chest to work again instead of just letting it sit in repose back in the storeroom. But I'm afraid of destroying any provenance it might have by repainting it. I really should repaint the top as there's nothing but faded paint on the top, but don't really want to hide or remove the artwork done by the original maker.
Any thoughts out there? I have a replacement lock for it as the original is hard to open. You have to fiddle with the key to get it open. The replacement lock was in the chest when I acquired it.
Am I crazy for wanting to use this chest, or should I just use it as a copy and build another one?
Thanks, Mike G. in the Foothills of S.C., where occassionally a needle in a haystack is found.
