Tried out my new toy *LINK*
Paul M in San Diego
>I just got a Veritas MkII sharpening station today, and I immediately ripped open the package and tried it out.
I've been vacillating on a new sharpening method for a while. I could either spend $300 on this sharpening station, or the same amount on 3 shapton stones and a flattening plate (give or take a few bucks). I was looking for a sharp chisel the other day, and I only had dull ones. I didn't want to dig out my old King combination waterstone and spend hours putting an edge back on them, so they just sat there dull. That was the final confirmation that maybe the hand-powered waterstone route wasn't for me and I need something quicker. I need something where it's not a long ordeal to keep up an edge.
Boy that is exactly what I got with this new sharpening station. The jig works well to establish a new bevel angle on my Japanese chisels, which do not necessarily have parallel backs and fronts. I was concerned that it might not work on them because of these irregularities, but that concern was eliminated. The main jig surface rests against the back of the chisel, and the clamp is on the front. This is the opposite of the standard Veritas waterstone sharpening jig where the front is on the reference surface and the back is where the clamp hits. That never worked well on these chisels.
It takes but a minute or two on the roughest grit to establish a new bevel angle. I've been hand sharpening these chisels without a jig, and the angles varied over time as the softer steel is eaten away quicker than the hardened edge. It was great to get the proper angle back on them so quickly. The three subsequent grits take literally a few seconds per grit. It takes longer to swap the platters than it does to do the sharpening at the next grit.
I then followed up with a bit of honing on my 6000 grit waterstone to take off the final scratches. I think this only took another minute or two per chisel. I'm a happy boy.
I did try to see how using this sharpener would work on the back of one chisel. That is a mistake I won't make again. I made a serious back bevel on that chisel just using the finest grit for a few seconds. It took a while with the waterstones to restore the back. It's just so easy to round the edge when doing the backs, as there is no jig or reference to help you keep the back flat on the paper. But backs are something you do once, and then maintain with only a fine stone when doing the final honing. I got this machine to help work the bevels, which it does with gusto.
Thanks Rob, for creating a well thought out tool. I'm always awed by the engineering that comes from your company. And thanks Lyn for helping sway this decision with your review.
-- Paul M.
MkII sharpener
