Hide glue mixing
Jack Guzman from Maine
>I'm starting to experiment with hide glue. I got a cast iron glue pot and a hot plate. I also got a candy thermometer that sits right in the glue.
My first attempt was a disaster. I tried a small batch.The instructions that came with the glue call for mixing equal weights of dry glue and water and slowly bringing up to 145 degrees.
I don't own a scale that can measure such miniscule weights so I guessed. The first mix I got was way too thin so I added a little more glue.The best I could get was a light brown opaque sticky mess with the consistency of caramel.I tried to add more heat,more water,then realized I was ready for more information.
So, Help? Anyone know what I'm doing wrong besides everything? Is there a way to get accurate mesurements without a gram scale?
My glue pot is two piece. One I filled with water. The other sits in the water and is where I put the glue. thanks---Jack
