scary sharp suggestion
Tony Z.
>Earlier this week, I picked up several different types of abrasive paper to find something a bit longer lasting and faster cutting for plane bottom flattening and blade/chisel sharpening. First results very impressive: using a 180 grit ceramic belt, I brought a 605 bottom to a moe than acceptable condition in no time flat! I cut the 4" x 36" belt into 3 equal length pieces and used 3M 77 to affix to my granite plate. The ceramic cuts very aggressively! I checked several times for flatness by "magic marker" slashes, and in less than ten minutes, I was getting all marks removing at the same time! After that, a couple "spritzes" with Rem-oil, seemed to aid in the finish--altogether acceptable, and equal to 320 or 400 grit SC! These are first results and definitely bear further flattening/sharpening, however, if any of you come across ceramic belting, try it! I also got some aluminum zirconia belting, but haven't tried it. I may want to go to 240 grit as the initial starting point, because of the rapidity and aggressinveness of the cutting.
Re: scary sharp suggestion
Todd Stock
>Just to show that nothing is new under the sun, seems like the 'trade name' was Iron Eater - think I saw it on OldTools back in 1999 or 2000?
Used Al-Zr to dress the surfaces of the Woodcraft Emmert clone - worked fine and made short work of it.
Re: scary sharp suggestion *LINK*
Tom Price
>Walter Barry, once a regular onthe OldTools list gave the use of ALZ paper the QuickLapTM moniker back a few years ago.
Below is a link to a page on my site where Walte and I relate our experiences.
- Tom
QuickLap and IronEater
Todd Stock
>I stand corrected - Iron Eater was the carbide scraper and QuikLap the Al-Zr...what ever the name, it works great and lasts a lot longer than SiC in the lapping roll.
Did not know it was that long ago - how time flies when you're woodworking.
