Hand planing and film finishes (long)
Christopher Schwarz
>On Monday Jim in Burlington, Ontario, posted an interesting question about a recent article by David Charlesworth in the April issue of Furniture & Cabinetmaking.
In the article on surface preparation (which is excellent), David discusses using film finishes on large panels that have been prepped by hand planing only.
He and his students have regularly observed that the sanding between coats of shellac results in a finish with "dull streaks." Essentially, the sanding between coats (with a sanding block) cuts through the high spots of the scalloped planed surface. So the high spots don't receive as much finish and these areas show up as dull streaks.
David recommends leveling the surface before finishing with a sanding block and a series of fine abrasives, a traditional approach that has worked for generations.
So why don't I have this problem with my work?I think I've got it figured out.
I admit that I finish straight off the tools as much as possible. When possible, I use a smoothing plane and take a .001" shaving or less (usually less) on the final pass. So the scallops are � at most � .001" at their deepest point.
I finish with clear satin Magnalac precatalyzed lacquer � a finish I've been using for eight years now. Plus, brace yourselves, I spray the finish on with an HVLP system -- very non-Neanderthal of me I'm afraid.
The ideal coat of Magnalac is 4 to 5 mils thick � essentially .004" to .005". So when I go to level my first coat of the finish (which sands very easily, by the way) I can usually level the finish without cutting through the film at all.
Then I usually apply another full-bodied coat at 4 to 5 mils and sand it. Then I apply a final coat. The thickness of that can vary depending on the project.
That's the best explanation I can give. You might encounter problems with a thin, hand-applied film finish, which can be as thin as 1 mil. But when you lay it on thicker, it's not an issue.
And, of course, leveling your surface with sandpaper beforehand makes all this moot, which is David's excellent point. It's a good article. If you can check it out I recommend it.
Chris
