Pays to Clean the Shop(long)
Mike G.
>Cleaned my shop today. Had to as I couldn't even turn around in it. started going through buckets and boxes trying to get rid of the detritus collected over the past year or so. Y'all know what I'm talking about, boxes stacked on top of other boxes or buckets of that hardware you just couldn't seem to part with.
I made a firm resolution that if it wasn't a tool or some hardware that was still in it's packaging, out it went. Since I'm a carpenter by trade, I had plenty of hinges, hardware, and locksets scrounged from various jobs.
As I was going through several boxes, throwing a lot of junk out, I ran across 3 hammer heads, one of them an old Plumb, along with a 3 pound spalting hammer. All they need is a little cleanup and some new handles. I also came across a T.H. Witherby 9/16" socketed out cannel gouge. I didn't realize my good fortune until I cleaned it up a bit with some machine oil and 0000 steel wool. The only problem with the gouge, is the previous owner had taken the handle out and beat on the end of the socket with a hammer. Slight mushroom problem here.
A question...Should I try to file the inside of the socket or just cut off the offending mushroomed steel and make the socket a tad shorter?...like a heavy 1/16"
Imagine my good fortune when I unearthed another box and found 3 S. J. Addis gouges, #20, #26, and a #28. After much head scratching and mumbling to my self, it came to me how those gouges got where they were. I was making a box for them and like a few of my projects, it got pushed aside for something more important. I remember putting the gouges into there box so I wouldn't forget what I was building the box for. It was only a matter of time until they became lost and buried under about a year's worth of pack-ratting and hoarding.( I gotta quit doing that!)
My shop still needs some more cleaning, but at least now I can actually get into it and turn around. Did I mention that my present shop is in a small block building about 9' by 8'. Every wall except for the wall where the door is, has shelves and benches with more shelves stacked on top of them...at least as high as the 6 1/2' ceilings allow. I guess my actual work area is about 4' wide by 6' long.
I've been working on building a small bench that I can take apart if need be. I've got the uprights and stretchers made, using sliding dovetails for the joinery, but it still racks somewhat. I'm wondering if a shelf, using sliding dovetails, of course, added about halfway up the legs would help with the racking problem. I'd like to build one like Roy Underhill, that uses M&T with locking wedges, but can't find any drawings or pictures of it. If I recall, he used a locking dovetailed type of M&T with corresponding wedge. It's supposed to be very solid, but can be knocked down if need be.
Mike G. in the foothills of S. Carolina
Re: Pays to Clean the Shop(long)
Mushroomed Sockets
Jim Crammond in Monroe, Mi.
>Mike,
Since the steel at the end of the socket is soft, it is easy to clean it up without cutting it off. I use a file on the outside and a reamer for the inside. The reamer I use is the short, cone shaped, fluted type used for de-burring the inside of pipes. Just chuck it up in a brace and a couple of revolutions and the mushroomed steel is gone. If this doesn't work for you, blame it on Cooper Suter, he is the one who gave me the idea.
Jim Crammond
Todd Hughes
>With sockets that are not to bad I just put them over a mandrill and tap around the outside with a hammer and cleans them right up. Can use the horn of a small anvil or bick iron but i have found a iron drift or fid like they use for splicing wire works fine.
Don't know anything about cleaning up my shop but did clean my car up and found 2 nice early backsaws I was wondering where they were as well as a bunch of other tools.....and I drive a Honda hatchback! .....Todd
Dan Donaldson
>I know that this is the handtool board, but I cleaned my shop this weekend and found a tablesaw in the middle of it. It was so covered with "stuff" that I almost forgot that I had it ;-)
