ADVERTISE HERE - FREE TRIAL
Disston saw questions
Jack from Maine
>I had a pretty good yardsale trip this morning. My first find was a complete post vice. Like I need another vice. I couldn't pass it up though.I gotta find a place to mount it now.Next thing you know I'll be looking for an anvil.
Anyhow,back to the questions.I also found a Disston 240 metal cutting saw. What sort of metal cutting was this intended for? Commonly used for?
Finally,I found a Disston 26"(length of toothed part of blade)miter saw.It's in nice shape,even sharp.I intend to make a miter box for this. It's too big for my other miter box. Anyone have pictures or ideas on some type of guide that will work with this saw?---Crackerjack
Re: Disston saw questions
Doug
>I don't know if you want a "store bought" rig or not, but you can usually find Stanley boxes w/o saws on ebay for $10 or so. I'm not sure, but I think your saw would fit the 246 mitre box.
L. Hanson in N. Idaho
>Nice find! Those old metal cutting hand saw were generally used for softer sheet metals and metals - tin, wrought iron, softer grey iron - metals that were common around the turn of the century in the building industries. Tin roofs were pretty common, for example, and these were used for cutting those sheets.
They are sharpened with no set in a rip profile, IIRC - no set, as they were "double tapered" or some such -
I checked, and here's about all that disstonianinstitute.com says about them:
"No. 240 metal cutting saw. ca. 1945-1950 18 inch blade, beech handle, 15 ppi. rip-style teeth, 4 degrees rake, .050 thick at teeth, double tapered, .040 at back near handle, .030 at back near toe."
And:
"Other specialty saws in the Disston line include the No. 77 backsaw with a similar ultra-taper design for use without set, the No's. 240 and 340 steel-cutting hacksaws shaped like a handsaw, and a No. 7 handsaw with a detachable back for backsaw use."
You might check the oldtools list for more info, if there is any out there, it is probably in there. Looks like the antique dealers on the web have generally listed them for between $75 and $150 depending on condition.
If you are interested in miter boxes that would fit your 26" disston - take a look at Jim Barker's page at http://www.azstarnet.com/~barkerj/MBoxHome.htm
Lot of good stuff there on Langdon Acme Mitre Boxes.
-Nordic
www.norsewoodsmith.com
Jack from Maine
>Langdon's site is a good source of info.Thanks.I like the price list."New Langdon Improved-$11.00 with saw".Too bad that isn't a current order form.
My miter saw would probably sell for a little less. It has some surface rust that will need to be removed.No problem as I plan on using it.---Jack
Jack from Maine
>I probably will go with a readymade miter box. The weight and length of this saw make a guide system necessary. I'll be ebay and flea market shopping til I find the right one. I'll look at the 246. The 250,which is pretty common,looks to be too small.---thanks---Jack
Ernie Miller Topeka
>The 240 were used alot by plumbers who had to go in and cut to make room for plumbing and would hit nails in the corse of the job. I just sold one on ebay for $20 which I think is low but I'm not a collector so I had to make room for somthing else.
