I've Seen the Light!!
Alan Hamilton
>I've been following the discussions about bevel-up versus bevel-down planes. I've been fascinated by the bevel-up adherents and their notion that a bevel up plane is more versatile because different irons sharpened to different bevel angles will make a single plane with all different effective cutting angles.
I had my doubts. I've always been a "bevel down" kind of guy, and I've never had the need to look around for anything else; my poor old bevel-down planes always worked just right. How ignorant I was.
But all those threads made me pause and think, and now I've seen the light! I bask in the inspiring light of of versatility. The more I ponder, the more is revealed to me; the more I look the more I see. I now understand. But I think even the most strident bevel-up champions have not seen all. Planes are much more versatile than anyone has said. In addition to them coming with a "finger plane" ready to go:
Planes are heavy, and they have a handle already in the right place. They would make wonderful hammers! The angle of the handle is much more ergonomic; and it would be hard to miss a nail with that big flat sole.
Think of the iron. One end is already a chisel, which leaves most of it unused. The other end, with a little grinding and stoneing, would make another size chisel! The iron has two long edges too; grind the thickness down a bit, file teeth, and presto! A saw! You could even file one edge rip, the other cross-cut.
The back iron can be equally useful. The heavy duty ones can be used as pry bars. The flimsier ones can have the top end shaped into a wonderful screwdriver. The kind with the hump at the bottom can have that end sharpened, and with a handle attached you have an adze.
This is great! I was living in ignorance. There must be more, more ways to use a plane I haven't thought of. I'm sure I've just scratched the surface.
I gotta go. Not only do I have work to do on my planes, I need to put all my other tools up for sale.
Alan
Re: I've Seen the Light!!
Joe Rogers, Northern Virginia
>Alan...you started off so strong. Then the medication must have worn off ;-). This thread could get hijacked so easily. I wonder where it will go next. Really sucked me in tho. JR
you're wrong Alan....
Dave Anderson Chester,NH
>The only correct response is to grab all the planes you can. ;-)) It is your solemn duty to spend the rest of your life acquiring all the examples of both bevel up and bevel down you can lay your mitts on. How else can you truly and accurately have a basis for comparison?
Look at the time stamp for this post. As soon as I shower and clean up I'm out the door to go tailgating at the LFOD auction in the never ending quest for more tools. This I refer to as dedication, Sue refers to it as insanity.
Tony Augruso
>But you are still in the dark ages! The world was not meant to be flat!
Open your eyes! See the true light. The earth is round. Explore the world of curves. Experience the pleasures of drawknives. Feel the exquisite contours produced by spokeshaves. Marvel at the beauty produced with carving chisels.
A plane is only the beginning of true light. You must go further if you wish to be truly enlightened.
Do not stop at this point or you will regret it for the rest of your life.
Remember, true light bends!
Tony
>Ahhhhhh, soooo tru, Grasshoppa!
