Pin Drills
Jack from Maine
>I needed to install tiny brass pins in beading to retain glass in a cabinet door. I got the pins at woodcraft, and while there I looked for some idea on how to predrill for those pins. What I found was a small pin drill with a set of various sized bits and two different mandrels for different sizes.
The tool itself is about 4 inches long with a free spinning knob. On the other end is the chuck,similar to a dremel chuck with removable mandrels.Behind this is a knurled piece that is the actual driver.By palming the knob you can turn the knurled piece with your thumb and finger. It works great.
I bought the tool figuring I'd use it that one time and maybe it'd be needed again someday.I've had it for a week and already I've used it on three separate jobs. I have to get a larger set of bits.
This is a revelation to me. I'm sure alot of you already know all about this amazing "new" tool,but I'm discovering new things in woodworking every day and I thought I'd share.
Crackerjack
