Half Blind trick
Half Blind trick
Half Blind trick
Robin Frierson
>Has anyone tried this half blind trick. When working with the drawer front, the pin board, you take a piece of sharpened bandsaw blade or scraper blade, and pound it down through the saw cuts so you define the whole wall of the pins prior to chopping any waste out?
I saw it on a Tage Fried video and just tried it today on a practice piece, and it worked like a charm. I am about the start the real drawers and wonder if its OK to continue using it? I am concerned about splitting the piece though.
Re: Half Blind trick
David Barnett - Venice, FL
>Works, but I was taught to NOT use a sharpened and beveled edge to avoid splitting.
Re: Yep
Tom Scott
>Sure, this works good. I've always used an old scraper blade, but as noted previously, it should be dull to avoid splitting.
Be careful on the outside 1/2 pins, and take it slow when using this method on them. I've also found that you should start at the inside pins and then do the outside ones last. This gives a little more relief to your 1/2 pins and reduces the chance of them splitting.
Tom
Blunt edge?
Robin Frierson
>So you just use a blunt edge, like the normal end of a scraper blade thats square? Dont sharpen it at all? That blunt piece goes in OK?
Re: Blunt edge?
>You can file it flat just like you're prepping it for burnishing, but don't turn a burr. If you're finicky, you can also cut a few very small 'rip' teeth from the corner for about 3/8", (on one of the ends, short dimension) so they cut when pulled toward you. No set. Works like a float to deepen and/or clean out the kerf left by the scraper.
Re: Yep
Fred in Virginia
>To reduce the risk of splitting on the outside pins use a clamp across the end to resist the splitting force.
Don't bother
Adam Cherubini, NJ
>Robin,
What you are doing is perfectly acceptable. I doubt you'd split your drawer front.
But I don't bother. Any examination of period furniture reveals overcuts on the drawer backs. In the past, some woodworkers have assumed these reduce the amount to be chiseled. Others have offered the technique you describe as an inevitable alternative.
I've found it a simple matter to dig the DT saw's heel into this cut, cutting very close to or on the depth. I believe this is yet another explanation for the peculiar handle found on tradition dovetail saws, dutifully and beautifully reproduced on Adria, and LN saws.
Happy dovetailing whatever method or saw you choose!
Adam
Re: Blunt edge?
Ted Owen, Pittsburgh
>I actually blunt mine even further than just filing.
I don't know why more folks don't use this technique on half-blind DT's.
Best, Ted
Re: Half Blind trick-putty knife
ThomD
>I do that, but I use narrow putty/taping knife. Just use it as it comes from the store, it has the advantage of rather than there being this piece of metal you are walloping with a hammer, it's pretty much set up like a chisel, Just drive it down. These knives come in a bunch of thicknesses, some a thick as a dime, others very flexy. I look for as thin as possible, with a little stiffness. I clamp the board to minimize any chance of spliting. It doesn't wreck the knife, I still use it for plaster.
Funny. I have know this trick for about 25 years. Yet until I saw the video I really didn't think it would work. Frid has a different approach to joinery from what I learned, and I always had a feeling like it might all work in mahogany and walnut, but forget it for the other stuff. But I worked throught he whole deal a few years ago just for something to do. The saw think and all that. It sure does work.
