Veritas - Innovation in Tools
The "Plane" truth...
Rob Lee
>Hi -
As I suspected last week - you're all good sports!
I have to admit that I got more nervous as I saw the hit counter on my original post pass 800, and then 900! (The entire thread was at 17801 total views earlier today).
The pictured plane is an early version of the new 62 1/2. We had planned to have it available next, but made a few tweaks to the body casting, which has added 6 weeks to the delivery date. The final version will sport a different knob, a slightly modified and re-located rear handle base, and of course, the new feature we're not showing just quite yet.
It's 15" long, 5.88 pounds, has a 3/16" A2 blade (2 1/4" wide). Toe length is quite long at almost 5" (4.81), and (sorry Lyn) it will have milled circles on the sides. The balance point on this plane is 1.92� behind the front edge of the bed (identical to the LA Smooth). What's really different is the center-of-gravity - which is .54" above the sole (versus .64" for the low-angle smooth and .98" for the no. 6). The lower COG and increased mass really sets this plane up well for use as a high angle plane, in addition to being a good shooting plane. It will have a LA blade as standard, with an optional pre-ground HA blade.
As for other plane, which will actually be available first - it's the #90 based bullnose/chisel plane. It'll have all of the features of our shoulder plane (except for the pivoting knob - as this plane is designed for an overhand grip). It'll be 1" wide, 4.7 inches long, and have excellent ergonomics.
The large (073) style shoulder will also arrive before fall, but is still far enough away that we can't nail it down to a specific month.
As for the promised tease - there's something new in the spokeshave line also in the May catalog, not a convex, concave, or cigar shave... nor a travisher. It too, has a patent pending.
Cheers -
Rob
Re: The "Plane" truth...
another tease
Dennis
>Hehe,no travisher but something else...........now iam going to cry
Dennis
remove nospam for email
I've never seen that post Rob...
HC Sakman
>...where is it???
Thanks,
Chico...
I got it! No worries.
HC Sakman
Sounds like Rob!!!
HC Sakman
>"Weighing in at 2-1/2 lbs (that's just the blade) and a full 1" thick, this blade is likely to induce chatter in your bench before vibrating itself. Blades are shipped with a pyramidal storage box, to keep the edge at it's sharpest when not in use.
Best use a micro bevel on this one, as you'll wear out entire stones honing the face."
I just kept grinning as I was reading these lines. They sound like you wrote them Rob! ;-)
Good one! Congrats!!!
Chico...
Will we ever be able to believe Rob?
Brent Langdon, Sterling VA
>I think maybe a $20 gift certificate for each forum member is in order to cover the pain and suffering involved!
- Brent
Tim
>Rob,
Since you are on a binge of announcing new tools......doesn't seem like much of a jump to me (but I've obviously no experience with machining and manufacturing...) but how about some A2 steel chisels, a la Lie Nielsen? If you can make a shoulder plane iron.....a chisel is pretty much the same thing, just add a wooden handle. I"m thinking in the ~$35/chisel price range......
and you guys need to slow down on these new tools, your abilities to produce new toosl is faster than my abilities to procure funds for them.... : ).
Tim
Tim...
Rob Lee
>... I answered you on another board...
But will repost snippets here:
No immediate plans to make chisels - we're not "tracking" LN, we're develeoping our own line of tools, from first principles, leveraging updated materials, ergonomics, manufacturing capability, design tools, and of course - our own brand of craftiness....:)
Is there a pressing need for more chisels made from A2?? The LN's look like a fine chisel....
If we did it - we'd probably scarf A2 inserts into a "normal steel chisel" - and price accordingly. We'd also do a through tang and a button tip.... A2's tough -why not make the whole chisel tough??
Anyway - it's all speculation....we're most likely doing something completely different, once our research is finished...
Cheers -
Rob
IMHO
HC Sakman
>Hi Rob,
I think "Iyoroi" (sp?) Japanese chisels are excellent performers/value for the money. I wish some paring and mortise chisels of the same brand are available through Lee Valley.
Chico...
HO #2
Well said, and I think that it is one of the reasons that Lee Valley is well respected. I would feel a loss if Lee Valley closed shop and there are very few other companies that I would say that about.
There does not seem to be a shortage of quality chisels on the market right now and I am surprised that people are getting excited about a $250 set. I would not mind seeing Lee Valley carry some "good" bench chisels in addition to the Hirsch. (from an amateur woodworker that gets by with a $25 set of Buck Bros chisels)
- Brent
