Plane Clean up
TheHeretic
>Quick question. Keep in mind this plane is for use and not resell or show.
I recently purchased a Stanley #220 plane that had a moderate amount of rust on the sole and sides. The japanning was at about 85%. The blade had moderate amounts of rust as well. To clean it up I used mineral spirits (no Kerosene on hand) a small brass brush to knock off large amounts, steel wool for more removal (ok that didnt work very well) and 320 grit Garnet sandpaper. Sole and sides as well as blade are now worlds better. There appears to be no heavy scrapes and when I get some I plan on using 600 grit wet dry to polish it up a bit more.
The question is this. Have I done any damage to the plane's sole or sides using the garnet paper? I also used the paper to rub out a the rust on the blade. I can see long "streaks" in the sole and sides but to me they dont affect the performance. I did all of the operations on a flat piece of Baltic birch as I dont have a granite stone around (yet).
I would just hate to have done any real damage to the plane in getting it ready to use. I am actually rather proud that it works as well as it does now. I used the scary sharp to sharpen the blade by going up to the aforementioned 320 with garnet and than using a 600 grit diamond stone. It is probably not as sharp as it could be but it will now function as a plane as opposed to the condition I bought it in, which wouldnt have cut hot butter in July.
Thanks for any advice. I did read the article found elsewhere on WC and that is where I made the decision to use mineral spirits. I didnt go so far as to use electrolosis on it but for now the plane is functional.
I have stood on teh slippery slope and have started sliding. Twas such a great feeling when it made its first swipes and cut nice long curly shavings!
Thanks
Dean
Columbus, OH
