Next problem - twisting panel... *PICS*
Scott in Douglassville, PA
>Ok, the same gremlin that's bitten me in this project before is at it again: After milling, flattening, waiting, flattening again, and dry assembling, one of the six panels on my chest has developed a little twist:
This amounts to about 1/4" twist over the ~16" width of the panel (and, yes, the front panel needs to be trimmed to final height). The board springs into place pretty easily with just a little pressure, so I'm wondering (hoping) that the nails (I was thinking four per side, and five along the bottom) would bring things in place without further grief down the road. FWIW, the thing's been flat up 'til now; we've had several major weather switches in the past couple weeks (warm, rain, cold, snow, cold, snow, warm again). Any chance it'll sit down on it's own again?
BTW, here's the dry-assembly, front panel snafu notwithstanding:
Thanks for any ideas.
Scott
Re: Next problem - twisting panel... *PICS*
Jim in Burlington Ont.
Jim in Burlington Ontario
>Nails will hold I would clamp and predrill. Those cut nails have incredible holding power.
Now I know your not...
Scott Burr in Ben Lomond CA
>suppost to use glue here, but maybe a drop on each end and 1 in the middle then clamp and nail? It's just a thought.
John Aniano in Central NJ
>Scott,
Yes, I would also agree that several nails would hold this into position and keep the panel from springing out, but here's some food for thought...
Years ago, while in high school and college, I made two toolboxes having the same construction as your project, i.e. vertical grain on the ends and horizontal grain running on the front and back. I also used rabbets to join the corners as you are doing. It took several years, but the mismatch in shrinkage between the front (back) and sides eventually caused the rabbet joints to fail. I had glued them instead of nailing. Maybe if I had, the nails would have allowed for a bit of "give" and the corners would have remained intact.
So, yes, nailing should pull the corners together, but in the future, you might want to think about an alternative joint or design to allow for inevitable wood movement.
John
>Hi, John -
Thanks for the help, but I'm a little confused: I'm just using nails on this. Did you glue the boxes cross-grain, or just nail them?
Too early - need more caffeine...
Scott
Re: Now I know your not...
>Yeah, I was pondering this, too. Just about 1" worth at the top corner, but I think I'll wait a few days to see if the changing weather brings things back...
>Thanks, Jim. Adds to the confidence level.
>I would not glue them. Glue will not provide the flexibility you will need to keep the front and back panels from splitting in the winter. Hide glue, poly and resorcinol would be even worse than yellow glue, which at least accommodates a little wood movement with "glue creep."
