Lever Cap Pressure Setting.
Richard Gillespie
>Being a self taught hand plane user isn't all it's cracked up to be. I'm convinced that my teacher is a dummy.
I thought that the lever cap had to be set so that the blade can't move in any direction. So I've been setting it where I can just release the pressure by hand. If I have to grab a screw driver to do it's too tight.
Yesterday, I watched a INTERNET video on hand plane use and was blown away when I saw the demonstrator adjusting both the depth knob and the lateral adjustment lever with the lever cap set. Is that correct? If so, the releasing the lever cap, making adjustments and resetting the lever cap like I've been doing has been totally unnecessary.
How much pressure are others using?
