Planing Methods
Richard Gillespie
>I posted a similar thread on another forum. I hope no one minds.
I'm seeking advice on the correct methods used in hand planing. I'm self taught and my teacher is a dummy. In reading this and other forums, I've gained many helpful ideas for the sharpening and tuning my CI planes. I've seen few threads on their use though. I've watched Roy Underhill's show several times where he has used a number of planes, mostly wooden.
I glued up a couple of Ash panels to make into shop shelves. They ended up slightly bowed edge to edge after coming out of the clamps. No problem, I had planed them to 1-1/16" prior to glue up and wanted 1" when finished. Using a #4 and a #5 Stanley Planes I went to work. Right off the bat, I misread the grain and caused bad tear out. In getting the panels flat, I was able to remove most of the tear out.
After flattening the panels I use a #7 jointer to straighten one edge and then trimmed the panels for length and width. Since they are shop shelves, I filled the unpaired tear out and and used card scrapers to do final smoothing. They don't look too bad for shelves.
The point of this post is, I was using the planes parallel to the grain. They were held slightly angled to the grain to get the best cut. The blades are scary sharp with a slight convex shape. Are there other methods I should consider or know? I'm not in a position to pay for a class at this time.
The bottom line is, I'm glad my first project was shop shelves and not a top for a table or piece of furniture. But I must admit, it was a wonderful, dust free afternoon in the shop.
