Modifying an old plane?
>I have an old Stanley #10 that I have been using for a few years, but up to now only for fine finish work in seasoned hardwoods. I now find I need to use it for some coarse softwood joinery as well. It is a type 7, built between 1893 and 1898. I have replaced the tote and the blade, because the originals were beyond salvage when I got the plane. The replacement blade is a L-N, which is a bit thicker than the original Stanley. I find that I cannot back up the frog and blade to make a thick cut, especially in longleaf pine ship timbers, because the sides of the blade are stopped by the back of the side cutout, even if the frog is moved back. It works fine for very fine shavings, but clogs on pine. Should I enlarge the back of the side cutouts or should I open the mouth? I don't think either will seriously adversely affect the collector's value of the plane, which is well beat up from several years of hard work before I acquired it, but other than the problem described, works very well. I have no desire to find a thinner blade, so that is not an option.
Does anybody think this old "user" grade plane is valuable enough, as is, that I could sell it to a collector for enough to replace it with a #101/4 L-N?
Remove NOSPAM for new e-mail address.
