Building an infill ?
Ernie Miller Topeka
>When you cut the brass pins that hold the infill to the shell how much to long should you cut the bradd rod? if the shell it 2" wide should the pin be 2 1/4"? more or less? also I am being a little unconventional my shell is made out of some galvinized channel iorn. I am thinking about japaning it befor assimbling the wood to the shell will japaning stich to galvanized metal? will I need to wash it down with vinigar like you do befor welding this stuff? THe shell should be counter sunk befor peening the pins in place right? Thanks I broke down and bought the brass rod this morning so a project might be coming to an end after several months.
