lost set on dovetail saw
Gary Williamson
>Hi folks, I am starting to learn dovetialing by hand and ran into a problem with my saw. I have a Garret Wade dovetail saw that I modified per advice that I have seen on this site. I filed the original teeth off and refiled new teeth at 14 tpi. I also filed and sharpened the teeth with a rip pattern. I followed the methods from Tom Law's video and Pete Taran's article on this site. I used a sawset that I bought from the "Museum of Woodworking Tools". Using a dial caliper I tried to get the set to .003" or 004" on each side. After all of that, the saw cut like the LN that I tried at "Woodworks". I was pleased. I am using poplar to practice my dovetials and have only cut about 30-40 dovetails.
Near the end of my last pratice session I noticed that the saw was binding and was hard to push. I examined the blade and it seems that the set has been reduced considerably. Is this normal after so little use? Is it possible that I used the sawset incorrectly and did not bend enough of the tooth?
Thanks in advance,
Gary Williamson
