140 plane 'handedness' *LINK*
Clay Craig in Miami
>Below, Lyn M. comments that the 140s seem reversed as to use - the RH version better for lefties, and vice versa.
Whew! I thought it was just me. When I look at the 'regular' 140 on the LN site, to me that always looked like it would work better for left-handers. I ssume that the 140 illustrated is indeed a RH version.
As a righty, I would like to be able to trim a tenon cheek on a push stroke with the 140 plane in my right hand (picture the work horizontal in front of you, with the tenon extending from the right-hand end, trimming the top face/cheek of the tenon). The one pictured looks like I'd have to reverse the work and then hold the plane in my left hand, or use it on a pull stroke with my right hand. Link below may help visualize.
This is correct? If so, I guess I'd better order a LH version before they're all gone.
Why is this - any ideas? What do all the RH 140 owners do? I have assumed that it's preferable to 'lead' with the point of a skew plane against the shoulder when trimming tenon cheeks, so the skew of the blade will tend to keep the plane registered on the tenon shoulder.
TIA,
Clay
LN 140 (RH, I assume)
