old fret saw thread *LINK*
Clay Craig in Miami
>I saw the above message from David Barnett in an old thread about the fret saws from Contenti - he recommended the non-adjustables so one could lean into the saw and tension the blade by springing the body of the saw itself - he also specifically mentioned the 'Lightweight' version linked in the page below.
Has anyone tried this one? Can you indeed 'lean into' this tubular frame and get anough spring? Can you adjust the blade at an angle or horizontally without twisting the blade itself?
TIA
Clay
Contenti sawframes
Re: old fret saw thread *LINK*
Dan Donaldson
>I have one that basically looks like the one in the picture. Mine works by leaning into the saw and springing the frame to get the tension. It is not a tubular frame, but some kind of flat steel. It is adjustable for blade length and handles scrollsaw blades just fine. I find that it works a lot better than a conventional coping saw for my uses and is very fast to tension and gets the blade as tight as you want it.
David Barnett
Two fixed sawframes from Contenti
David Barnett
>The two fixed sawframes from Contenti are the "Lightweight" Grobet tubular sawframe, and
the "Best Quality Sawframe", which is the strongest of the two and probably better suited to the heavier blades (with less teeth) used for wood. Both of these work fine for sawing out DT waste, though.
However, of all the Contenti sawframes, I don't recommend the "Economy Sawframe". It's an adjustable sawframe that is too weak for what I consider adequate tensioning, and is easily sprung/warped, although one can get by with one for light work if care is taken to use only lighter blades at low tension (1/0 through 8/0, maybe). These cheaper sawsframes (sold by nearly everyone, it seems) often frustrate beginners by making it difficult to control cuts and by greater blade attrition.
David Barnett
Alternatively, an improvement (maybe)... *LINK*
David Barnett
>on the fixed lightweight sawframe is the newer one than what is pictured on the Contenti link. The old one has levers to tighten the blade, whereas the newer version has round knurled nuts, which I prefer, as one is likely to bang a lever now and then which can (although not often) loosen the blade. On the other hand, I'm not sure the knurled nuts grip the blade quite so tightly. Your call. I know, I muddied the water, heh.
Anyway, Contenti probably has the newer model even though the picture has yet to be updated. Just ask them to check. An alternative supplier (another good company) that pictures the newer one online (albeit at a dollar or two more), is:
FDJ Tool
