A very usefull tool *LINK*
Paul Barnard
>I'm in the throws of laying a hardwood floor. Not a lot in the hand tool line apart from this problem and rather efficient solution. The kitchen had vinyl flooring and a 3/8 underlay. The underlay was stapled down with 1 1/2 inch staples on 1 inch centers. Yes you read that right, 1 inch centers. Can you get a machine that rolls along the floor banging in staples or was the floor layer just demented? I don't know how many thousands of staples that makes but it was a lot. The worst of the problem was that the underlay just fragmented as it was pulled up and all the staples were left behind in the floor. A claw hammer couldn't get a grip on them, a screwdriver just pulled out one end and pliers didn't have the leverage needed. I sat amid the sea of staples for quite some time almost in tears. I didn't want to bang them all in as it would play havoc with nailing the floor down. Anyway a quick scan of the Lee Valley catalogue and I rushed off to buy the tool in the link below. It really works well. It does exactly what it's name suggests. I spent the whole of Saturday and Sunday crawling around the floor pulling out the staples. I collected a gallon ice cream container of them, and a set of aches and pains that have to be experienced to be believed. If you are faced with a nail pulling dilema this tool is a great solution.
LV Nail puller
Re: A very usefull tool *LINK*
>Very clever adaptation of an old design -- I can't recall what the name is, but the original design is larger, with a slide-hammer arrangement, designed for demolition and capable of removing a thoroughly sunk-in 16d nail, although the timber isn't worth much when you're done removing the nail. I somehow have acquired three of them...somehow.
If I ever re-do our kitchen, which has lots of ring-shank nails holding down particleboard underlayment, I'll have to write Lee Valley first.
Harold Blair
>Paul: you are correct about the nail puller. I am restoring an old house. In the process we are taking down all the walls and ceiling boards. This consititues removing over 6,000 LF of 1x6 T&G. It would have been impossible w/o the nail puller.
Peter Ulmanis
>This one of those "why didn't I think of that" designs accompaied by a self inflicted head slap.
One question, what is the tool made of. Does it leave a dent on the wood at the pivot point?
Peter
Harold Blair
>Made of metal. Typically it does not make a dent at the pivot. Of course it makes a small gouge when it "bites" the nail head.
Pulling nails/staples
Bill Ward
>I have a whole arsenal of nail pulling gear. For major deconstruction, you want the slide hammer style puller. I think Greenlee still makes these ($35-40??), but old ones are pretty easy to find at antique stores and flea markets. I have three right now and have sold a few to my Habitat for Humanity buddies. I buy them whenever I see them for about $10. If you get a used one, make sure the jaws are not broken (or repaired) and that they close properly. Common brand names are Pexto, Rex and Greenlee (probably lots of others). These big guys will grab 16d common nails without a problem.
I also have had good luck with the little guy that LV sells. I use it on smaller nails or when the big boys won't fit. The LV puller stays in my tool belt (I mess up a lot of nails!).
For staples (like the above underlayment problems) I've had good luck using fencing pliers. Those are the 5-in-1 sort of pliers. The top of the staple has to be exposed to get a bite to use these.
Re: Pulling nails/staples *LINK*
Kirk in HMB, CA
>For Pulling staples, I prefer a pair of end cutters. Used gently, they let you pull the staple with minimal damage to whatevers underneath. They let you get a grip on both legs, less worry about the staple breaking.
If you're too rough, you end up with broken staple legs, which I just hammer down.
End Cutting Pliers
Jim in Burlington Ont.
Jim in Burlington Ontario
>I am not sure if you pulled up the subfloor or not? But a roofing shovel is a handy thing to use.
>The end nippers are very good for this job. I've unfortunately too much experience pulling up disgusting old carpet out of this house and these are just the bee's knees. I bought a Crescent and it is very good indeed.
Don't be conned and buy the cheap Indian/Chinese versions. They suck big time. DAMHIKT.
Paul Barnard
>I resorted to a garden shovel :-)
AKA the roofer's friend
>The square shovels are best for this.
