Re: Japanese Chisels
Scott McIndoo
>Japanese chisels are desgined with the hollow on the back to make it easier to flatten the back to create a perfect straight line on the bevel edge, as opposed to western chisels which have a "full" back which is painstakingly flattened when sharpening, resulting in a lot of material removal and wear on the stone.
Don't tap out the back, as you will uselessly remove material prematurely. Every time you flatten the back of the chisel (usually whenever you sharpen) you decrease the depth of the hollow, but the portion just behind the cutting edge grows in length, providing more strength behind the edge.
Re: Re: Japanese Chisels
dburnard
>Nothing wrong with tapping out the back of a chisel, especially if it didn't start out flat, or got distorted from (mis?)use. You'll be removing the same material as if you just flattened the back except that you won't be removing so much of the hollow elsewhere on the back. It's likely a personal preference but I don't like the looks of chisels that have had a 1/4" flat area removed all the way around the hollow - front back and sides. I don't see the need to do it either whether you tap out occasionally or not. YMMV
Jeff Schmidt (KY)
>Dave,
How is that timber frame shop coming? Have you posted any more pictures?
I agree. Hi, Dave.
Pam Niedermayer - Austin, TX
dburnard
>Somewhere along the way the City strongly suggested I make the blacksmithing separate - so that derailled me for a season or two. No new pictures of late but I'll try to get some up fairly soon. I still can't work in the shop, right now it's full of exterior trim boards, window frames and other construction materials.
One again my day job is interfering with my hobbies! Dang it!
