Bench Drawers?
Bench Drawers?
Bench Drawers?
Ernie Miller Topeka
>How deep? and how many? my drawer boxes are 17" wide and 24" high I know I want at least two to be shallow for layout tools but what do you all keep in you other drawers? I am thinking about making one for chisels. with racks for individual racks that hold differant sets. The racks would slide into holders that are in the drawer at an angle 25� to 30� this way I should be able to get 4-6 racks in a drawer all chisels would be handy I could pull out just one or if needed I could pull out the entire set. What about block planes? do you store them in your bench? I could probably do them on diagonal frames also to fit more in a drawer also. what other tools should I be putting in my drawers? I am making three boxes and having one open on the back side of the bench where I do my dove tailing what tools do I want in there besides layout tools?
Re: Bench Drawers?
Re: Bench Drawers?
>Instead of the complexity of slanted racks for things like carving chisels, to take full advantage of deep drawers, you should consider making several shallow drawers, just deep enough for one chisel. In general, that works for things like layout tools, and block planes on their sides, etc. Much less chance of something getting buried, so you have to dig for it, everything is visible, and it's a lot easier to rearrange the drawers as your collection of working tools and your work habits change.
Re: Bench Drawers?
Re: Bench Drawers?
Ernie Miller Topeka
>I don't want things getting burried or junk drawers. I have alot of factory made drawer sides that are 2" & 3" deep I was palnning on using it for some of the drawers but might just make most all of the drawers out of it.
Re: Bench Drawers?
Re: Bench Drawers?
Russell Seaton
>The drawer boxes under my bench will be roughly 17" tall by 21" deep by 26" or 31" wide. I plan to put three 2" tall, one 3" tall, and one 6" tall drawer in each box.
I determined these dimensions by looking at my big Craftsman toolboxes where my tools are now stored. The top drawers hold my chisels, layout tools, and saws. These are all 1 7/8" tall inside. Everything just fits.
Next are some 2 7/8" drawers and these hold block planes, spokeshaves, charpening equipment, drill bits and their cases. Everything fits pretty well here too.
The 6" drawer height was determined by measuring the height of my #7 planes. The old Stanley is 5 1/2" tall when sitting on its sole. So the drawer is tall enough to hold this plane and all other becnh planes. Planes can also be laid on their sides and then they would only be about 3" tall but would be harder to grab out of the drawer. If I get a #8 and it is over 6" tall, then it will have to go on its side in the widest drawer.
I like many shallow drawers over a few deep drawers. And my chisels and layout tools just lay in the drawers without any special racks or anything.
Re: Bench Drawers?
Re: Bench Drawers?
>It the drawers I made, the block planes just fit, on their sides, with cutouts glued to the bottom to keep them from sliding around. The problem is that sometimes shaving fall into the drawers, and when I put the planes back, the drawers get hung up on the planes. Give yourself at least an eighth inch clearance.
Re: Bench Drawers?
Re: Bench Drawers?
>Do you need to know how tall a #8 is, just in case? I like my bench planes set on their soles. Only block planes on their sides. Traditionally, wooden molding planes are put in very deep drawers, on their noses, so you can see the profile of the base from the top of the drawer. It doesn't make sense to have to pull several of them out to see the profile. That, I guess, is why they are all the same length.
Re: Bench Drawers?
Re: Bench Drawers?
Ron in Kokomo
>Please do not be offended by this simple observation. Make sure that you can get to the stuff in the drawers when you need it without having to disassemble whatever you may have clapmed to the fron of your bench. DAMHIKT
Ron
Re: Bench Drawers?
Re: Bench Drawers?
Ernie Miller Topeka
>Why would any one do something like that? Another reason you don't have any thing untill you have two of every thing. go for the back up. don't keep back up in same drawer.
Re: Bench Drawers?
Re: Bench Drawers?
Ron in Kokomo
>I can remember at least two times where I had to get something from a bench drawer that took an extra half hour because I had to completely dismantle a set-up on top of the bench and then get the item and then re assemble the set up.
That's why I do not like to keep frequently used tools below the bench. I realize that shop space often will dictate otherwise and that foot print is to big to be wasted.
Ron
Re: Bench Drawers?
Re: Bench Drawers?
>That's one reason why I built my bench drawers to open from either side of the bench.
You got that pile-o-block planes stored away in drawers yet?
Re: Bench Drawers?
Re: Bench Drawers?
Ron in Kokomo
>I have about a hundred block planes. ( some of them very crispy and cool) stored in a couple of boxes inside Rubbermaid crates. Ditto with spokeshaves.
I just moved some stuff down in the basement where I will be able to set up a small Neander shop. I have family with athsma and want to produce no more dust that ordinary living does.
I have to dismantle my work bench and carry it downstairs then re assemble it. I have a power
tool woodworker next door, and if I do not abuse the provilege I can get some stock thicknessing and ripping done there. I can do the rest " the proper way" I actually have so little shop time now that it is not much of an issue. I am about 4 or 5 years away from " gettin back into it" like I was. I do miss it some, but what is taking its place in my life now brings such rewards that I do not complain. BUT I may get a little shop time in tomorrow morning before the rest of the squad gets up
Good to talk to you Bill
Re: Bench Drawers?
Re: Bench Drawers?
Ernie Miller Topeka
>I have a little shop in the basement and just love it. I can work down there why the wife is sleeping and not to much mess. I'm working on pictures for a tour.
Re: Bench Drawers?
Re: Bench Drawers?
Angelo in Cornwall, NY
>I'm at the same point myself. First, I decided on 2 18" boxes and then a 10" box in between. On the 18" boxes there will be 2 2.5" drawers, 2 4" drawers, and 1 6" drawer. The 10 inch box will get a 10 inch drawer on the bottom, and 5 2.5 inch drawers above. I figure those 2.5" drawers will be good for chisels, layout tools, and drills, while the deeper drawers can hold planes and the 10" one can hold various tailed assistants.
Re: Bench Drawers?
Re: Bench Drawers?
>It's good to hear you're getting back into it, Ron. I haven't seem much of you in quite a while 'round these parts.
Re: Bench Drawers?
Re: Bench Drawers?
>Russell,
Seems to me I figured out once that my No. 8 would fit in a drawer 6-3/8" deep. If you need me to check this weekend, I can.
Bill
Re: Bench Drawers?
Re: Bench Drawers?
Russell Seaton
>Thanks. You can check, it would be nice to know. But I don't think it would matter. I don't have the room for a 6.375" deep drawer. With a 1/4" plywood bottom, this would be about 6.625" deep. Then I would have to pare an 1/8" or so from all of the other drawers.
Hmmmm. Maybe I could do that. I'll have to remeasure the absolute minimum I need for the shallow drawers and see how much extra space I'll have in the drawer box. I have two #7 planes so its not like I need a #8. But if I should run across one at a bargain price, I'm sure I will buy it. And it would look so cool to have all of the bench planes in one drawer lined up side by side. Ahhhhhh.
Re: Bench Drawers?
Good news: I was wrong
>My low-knob, old, Stanley No. 8, with the iron retracted as far as it will go (and an iron with not much use), is 5-5/8" to the top of the iron, so a 6" inside-depth drawer should work after all. I don't know whether L-N planes are taller, or Hock irons or any of that.
Re: Bench Drawers?
Thanks
Russell Seaton
>A regular old #8 will fit then. I had thought of the Lie-Nielsen #8 being probably taller. But then I remembered it costs $475. I figure it will be awhile before I get it. I reckon a regular old Stanley #8 will be found and bought first. If I have to replace the blade, I can always cut off the top inch or so above the cap iron slot to make it shorter, if need be.
Re: Bench Drawers?
Poverty has its virtues...
>or at least we who share it like to believe so.
Every once in a while, for chuckles, I list all the L-N planes that I'd buy if I had lots-o-money, and then chuckle when they total somewhere north of $1500. I'm not sure if I've got that much money in my total tool inventory (that's expenditure, not worth), though I may be fooling myself.
Re: Bench Drawers?
Re: Poverty has its virtues...
Russell Seaton
>I've done that too. I have a complete list of the bench planes in a spreadsheet and Clifton or Lie-Nielsen or Veritas by all of the ones I want. Almost all of them except the goofy #1. I don't want that plane. I want the Lie-Nielsen 4.5, 5.5, and 8. Only $1100 total. Much less than your $1500. Of course these unacquired Lie-Nielsen planes would merely supplement the set of Clifton bench planes already acquired. And a few Stanleys.
Re: Bench Drawers?
Yesbut...
>How could you get ALL of the LN bench planes, and not want that one last plane to make a complete set? It would bug me every time I looked at them!
(not a problem here, yet - 8 planes to go)
