200+ woodworking book reviews
Developing a Tool Set for a Wood Carver long
>Back before the Holidays, I mentioned that I was working on a carving �vise� for my son, Ross, who has recently become interested in wood carving. For starters, I turned him a carving mallet from cocobolo. There was no disguising his pleasure with this present. After Christmas, he went home with a few other carving tools, and some "firewood" that we scrounged from the Lox Toolworks. We have to watch SWMBO really close, what with Global Warming, as she really likes the fireplace, to be sure that only BTU-grade scrap is carried out of the shop.
I have made some progress on developing a carving system for Ross. It needs to be compact, because he doesn�t have room in his small apartment for a full size bench and a patternmaker�s vise.
Everything I'm presenting in this post is "prototype." That means it is a bunch of half-baked experimental kludges that are not guaranteed to work for either your application or mine, or Ross's. But maybe, we can develop some more ideas from it.
The design for the carving platform is derived from plans I found in a carving e-zine, Carving World. I built the platform, attached a benchhook type fence to the front and made some movable fences to set in place at the back and sides.
These fences are somewhat "beyond stock." Features include moveable round dogs and two different sets of dog spacings, to allow the fences to be set at either 90� or 45� to the edges of the table. I will find out whether the extra holes in the sides get in the way. I suspect they will, and a separate set of 45� fences will work better.
I have not yet built Woodcarving.com's "pipe dream" base for the table, because of my son�s space limitations, so I cannot comment on how well it might work. I did build their equiangular spiral cam clamp, using an angle of 80�. I found that it didn�t hold, so I built another one with a shallower angle of 82�. It wouldn�t hold either, so I decided I was wasting time and materials. That design has its shortcomings -- It seems it would only work in a much larger size and an even shallower angle. We can discuss this topic later if anyone is interested.
I looked at the other clamp promoted in the article, the one operated with a large eye-bolt, and decided it was not going to suit me either, because I�m spoiled by my patternmaker�s vise with adjustable jaw angles, and replaceable jaw inserts, which can accommodate a wider range of grip geometries. Woodcarving.com�s clamp just didn�t seem to have enough flexibility. So, I considered the designs of wooden hand screws, both with wooden threads and metal threads, and the workings of the holddowns that I built a while back (an adaptation of someone else's design). I show a new application of one of these holddowns to this new design in the last section of this post.
The first two photos show the assembled clamp in operation. The fences and jaws of this version are made from 11/2" square stock, and are therefore too high for the at-hand carved work-in-progress saw handle I used for the illustration. This is not a serious issue, since everything is made from scrap and simple, cheap hardware, whose dimensions can be modified at will. The modularity of the system allows the stationary and movable appurtenances: fences, 3/4" dowel dogs and clamp jaws, etc., to be adapted to the needs of any particular carving project.
There are three assemblies. First is the monolithic, replacable jaw. The face can be cut, sawn or carved to any shape needed to hold the work. The two screws are identical. The threaded rod is glued securely into the handles. The center block is a threaded nut attached to a dowel that drops into the table. The threaded rod rotates freely in the knuckle joint, and the knuckle joint rotates freely in the jaw.
The following photos show materials and constuction details.
I used a 11/2" Forstner bit to drill the sockets in the jaw for the knuckle joints. This poplar jaw may well prove to not be strong enough, since the knuckle walls are only 1/4" thick, and I may have to build a sturdier one. The holes are on 41/2" centers.
The screws are built from four subassemblies, the rod, handle, nut and knuckle.
The handle is turned hardwood, with a brass ferrule, and a deep hole the same diameter as the threaded rod. I have described my methods for making handles elsewhere.
The rod is a length of all-thread with two nuts jammed onto one end. With a hacksaw, cut the threaded rod to length. Smooth the ends of the threads with a triangular or cantsaw file. I also run a die all the way down the rod, to make sure it operates freely on the nut. Thread two nuts on one end, and with a pair of wrenches, tighten them against each other. You don't want them to ever work loose.
The knuckle is turned from a length of hard wood. It must turn freely in the holes drilled in the jaw. Make the jaw first, and use it as a gauge when turning the knuckles. Cut the knuckles to length. You'll need a V-block for your drill press to get accurately centered holes. Drill a pilot hole all the way through, centered on the length. From one side, drill a hole the nominal diameter of the threaded rod (5/16" diameter). From the other side, drill another hole, about 3/4" of the way through the knuckle, that allows the jammed nuts to turn freely (use a 5/8" bit for 1/2" nuts). Insert the rod, drop in a washer that will act as a bearing against the end of the nuts, and glue in a wooden (5/8" diameter) plug. allowing enough room inside the joint for the rod and nuts to move freely. After the sparingly applied glue has dried, trim the end of the plug flush with the outside diameter of the knuckle. I use a block plane and sand paper.
The nut is assembled from a length of dowel, a square block of hardwood and a piece of threaded rod connector. For 5/16" allthread, these are about 17/8" long. I made two nuts from one connector, by cutting it in two with a hacksaw. Alternately, you can use T-nuts. Drill a 3/4" diameter hole in the end of the block, most of the way through, and glue in the 3/4" diameter dowel for the dog. After the glue has dried, drill another 5/16" hole through the side to fit the all-thread. Centered on this hole, drill a 1/2" diameter to the depth of the half of the connector you made. To fit the connector into this hole without splitting the block, you will need to do a little carving with a veiner (V-groove tool). Center the end of the connector on the hole, and tap it with a mallet to indicate where the corners need to be carved. After cutting shallow slots all the way to the bottom of the hole, use the mallet to drive the connector into the hole.
Thread the rod and knuckle into the nut. The connector should face the knuckle, not the handle.
Finally, glue the rod into the handle. Epoxy, polyurethane, or PVA works. Alternately, Jorgensen uses a rivet in a hole drilled through the wooden handle and through the steel threaded rod.
Sometimes, it is more convenient to clamp the work down onto the table, instead of sideways between jaws. My original plan was to embed a matrix of threaded inserts into the top of the table so I could use my holddowns. Then I had an inspiration. One threaded insert could be embedded in the end of a dowel and the dowel inserted from the bottom of the table, if it had a head so it wouldn't pull through. I already had one that I could adapt.
Some dimensions of the one I built, provided as a benchmark for adaptation to your needs:
The table is 2" thick, glued up from three sheets of plywood, and framed in hardwood scraps. The bottom fence is screwed and glued to the bottom. A single piece of wood would have worked for the front face and fence, but that would have made it a bit more difficult to drill the dog holes. The 8 x 9 matrix of dog holes are 3/4" in diameter, on 11/2" centers. The round dogs are cut from 3/4" diameter dowel, 31/2" long. The fences are 11/2" square. The threaded rod, nuts, threaded rod connectors and threaded inserts are 5/16"-18 NC. The threaded rods are 9" long. The holes in the handles are 3" deep x 5/16" diameter. The knuckle joints are 11/2" in diameter. The clamp jaw is 11/2" x 11/2" x 61/2".
Let me know what you think about this design. I'm always looking for improvements.
Re: Developing a Tool Set for a Wood Carver long
GolfSteve in Calgary
>Great work. This reminds me of the Lee Valley carver's bench and their bench pup system. I like your wooden clamps better than the Lee Valley brass ones because I'm paranoid about destoying a perfectly sharpened edge by an inadvertent slip of the gouge.
Re: Wonderful!
paul womack
>That's a brilliant piece of design and manufacture.
The only alternative would be a scaled up version of an engravers vice, which has 2 flat jaws, the surfaces of which are littered with holes for small pins.
It's a bit like a tiny workmate, I suppose.
BugBear
Paul in NJ
>William,
Nice job of engineering, it looks like it will be extremely versatile. I am sure your son will be most appreciative of your efforts. I only would add some red 'Loctite' thread locker to ensure the jam nuts will never loosen. Thanks for the well-written post and sharing with us.
Paul Dzioba
CBT
>Amazing work. Thanks for all the details and photos. Perhaps this could be included in the WC Articles section or shop shots.
I am new to carving and my standard bench not the best solution for carving. You really gave me some ideas.
Curtis
>You're right about the inspiration of the L-V system. I forgot to mention it. In fact, I have one wonderdog, but the post is too long for a bench like this. Their wonderpup would work better, and you could adapt a pair of them to this jaw design by attaching a circular knuckle to the pup.
For those who like to build their own tools, the cost of this one (if you don't count your labor) is a lot less than L-V's system.
Jim in Burlington Ont.
It's just not fair
Jim in Burlington Ontario
>I got slippers and a HD gift certificate I am trading fathers. Seriously that is really nice looking and inspiring. Thanks for posting those great pics Jim
I'm available for adoption ;-)
Dan Donaldson
Pam Niedermayer - Austin, TX
>That's a superb, inventive setup that I'm going to steal. Now I've just got to come up with a bench angle adjustment system. One thing I'd add is a poppet type vise for carving legs; but that's a scale issue you didn't have to solve.
Thanks,
Pam
>For a cheap angle adjustment system, follow the link I provided to the Woodcarving.com article.
I don't use poppets for shaping and carving legs, but I have a patternmaker's vise. I put a pair of jaws with v-grooves, rotate the vise all the way to the horizontal, grab the leg by the post, and put a pad or a wooden mallet under the ankle. I'll try to post a photo later.
>Thanks, William, I had made note of that angle adjustment system, very nice, I'll probably use it because an emmert type vise isn't in the cards for me without a windfall.
I really like Phil Lowe's use of a regular bar clamp in a bench vise for the leg carving; but I need to rearrange the shop to implement. I also think I'm being a bit silly about this carving vise/table thing. In the Headley and Hall carving videos they simply glue the piece to a rectangular board and brace that. In the Headley card table video where he carves the leg, he uses a very wide bench vise or no vise at all, uses the mass of the leg and gouge direction.
Will love to see your photos when you have time.
Pam
Very nice William
Scott Burr in Ben Lomond CA
>Maybe you could make one for Mr. Bill Houghton. That way he could use it to carve pumkins for the festivel at HMB;^).
Holy Molly!
Jorge Castañeda ~ East Penobscot Bay
>William,
That is nice, promise i will borrow heavily when I get to carving.
Thanks for posting
Leg carving clamp *LINK*
Dan Donaldson
>Pam, here is a clamp that I made for carving legs.
Leg carving clamp
Re: Leg carving clamp
>Interesting, looks real good. I got a toggle clamp a couple of weeks ago for the mortiser, bet some combination of screw and toggle would be feasible and provide quick changes after setup. I love your setup, the fact that there's no big hunk of metal near the leg and it requires no bench vise.
I have to go over to Woodcraft tonight for the woodworking club meeting, will hunt about.
Many thanks,
Pam
Mark Meier (Ann Arbor, MI)
>That's a really nifty setup. Nice to look at too. Thanks for the post.
Mark
I'm in awe - as always!
Dave (Arlington, VA)
>Hi William -
I just want to add my 2 cents to the complements you've received so far. Each of these tools is wonderful! I really appreciate your posting pics of them.
I do have a question on your mallet. I got some measurements of Dave Anderson's mallet when he stopped by Springfield on the way down to Williamsburg last month - and then promptly left them at the restaurant. Bummer!
As I told Dave at the time, I have a decent size hunk of dogwood and would like to make a mallet from it. If you don't mind sharing, what is the diameter of your mallet at the top of the mallet head - and at the bottom. Also what is length of the mallet head (so I can figure out the angle of the head's slope) as well as the mallet's total length? Would these dimensions only be appropriate for a carver - or would they also work for more general woodworking?
Your son is fortunate to have such a nice, thoughtful and talented Dad.
Regards -
Dave
Re: I'm in awe - as always!
>I didn't measure the mallet, except roughly the maximum diameter and length of the grip, which I made a little over-sized because Ross has even larger hands than I do. For the rest of it, I just turned away everything that didn't look like a mallet. As long as you get the angle of the striking surface about right, you will automatically adapt your swing to it. Every different chisel length and material surface height will marginally affect your swing and therefore the "sweet spot."
I'll e-mail you a scan of the measured drawing I used when I built my first one. I shouldn't post it here, due to copyright issues. Everyone else should buy the issue of ShopNotes where it was originally published, along with all the good instructions.
Size is also important, and varies with wood density. Too large, and you will get tired swinging it all day, but too small and the force will not be effectively transferred through large gouges into the wood. Again, a wide variation in size works OK.
For general cabinet assembly there are advantages to a flatter head, since that would spread the force out better, and lessen the chance of putting dings in the wood you are bashing together. Foror striking mortise and bench chisels with wooden handles, there are advantages to a head that strikes the chisel with end grain, because it is more durable. You don't need to strike carving chisels so hard, and therefore a more adaptable head, like the one shown in the photo, makes it easier to aim.
If you turn a carver's mallet, I find it is nice to be able to set it on the bench on its top, so I turn the top just slightly concave, so it won't fall over.
If you are a pro carver, the corking of carving mallets is illegal :^)
Dan Donaldson
>You just have to make sure that you never break a corked mallet in public, so you won't get caught.;-)
One other Q
Dan Donaldson
>Sir William, you can't post the drawing due to copyright, but could you just post the diameter at each end of the head , the length of the face and the overall length as dimensions?. The handle is very individualized anyway, and this info should be enough to make one.
Re: Mallet Measurements,
>Some numbers: First, the mallet from the August Home plan:
Head max diameter: 31/2"
Head min. diameter: 3"
Head length: 31/4"
Length overall is 103/8".
Between the head and the grip is a collar with a cove and a flat step at each end. The collar should be about 1" long, and the step that transitions between the collar and the head about 13/4" to 2" in diameter. You will sometimes hold the mallet by the collar for light, accurate taps, so make it comfortable. If you wrap your thumb and forefinger loosely around the cove, their tips should just touch.
That part of the handle you actually grip is 5 1/4" long, and is ogee shaped. At the hilt, the flat step is 11/4" in diameter, then narrows to a neck of 1", increases again to 11/4" and then decreases to 1" at the butt end, before the decorative knob.
The one I use, the light colored one in the following photo, is much larger. The head varies from 4" in diameter to 31/2" and is 4" long. The maximum diameter of the grip is about 11/2", but that is too large. Even if you have extra large hands, any more than 13/8" is too large. It's overall length is 113/4", and the length of the grip is 6". If this one were made of cocobolo instead of sugar maple, it would be much too heavy. As is, it weighs a hefty 24 oz.
If you have small to medium hands, a maximum grip diameter of 11/8" or even 11/16" would probably give you a better grip. To tell if you have the shape right, take a very tight grip. The tips of your index middle and ring finger should not quite touch the ball of your hand. The tip of the little finger is less important. Remember that what is important is the distance around. If you take the diameter down a sixteenth, it will decrease the circumference by a fifth of an inch. A little too big is better than a little too small.
In this photo, I have also provided another example with one problem. The shape of the grip of the small, dark mallet is wrong. The maximum diameter should be moved much closer to the head. (Even the large mallet would benefit if the widest part were moved a little closer to the head.) It's collar, with a minimum diameter of 17/8" could be a little smaller, but it still works well for adjusting wooden planes. In Osage orange, it is 15 oz.
Head max diameter: 31/4"
Head min. diameter: 21/2"
Head length: 31/4"
Length overall is 91/4".
I will ask my son to measure the one I made for him. While I prefer a head diameter larger than that one, I was limited by the size of the available block of cocobolo.
I hope this helps.
Paul Brandley
>Sir William, with each one of these creative projects / posts, it becomes more obvious why you were Knighted!
Thank you kind Sir ;-)
Dan Donaldson
>Me, too, have one question. It appears that a popular design is rounder and more of a sphere. Do you know why this design is popular? It seems that unless you hit just right, the force would slide right off the mallet, make for bashed hands, fingers, and work. Is it just people who don't know enough, like me three years ago :), who buy this style? It does seem to work fine.
Pam
Re: Developing a Meta Tool Set  *LINK*
>It's just something I feel I can do to help support WoodCentral, and especially my favorite place on the web, the Hand Tools forum. If y'all find this kind of stuff as useful as what you find in books, magazines, videos or classes, go here, and make a donation. Also, don't forget to use our commercial sponsors first when you need tools and materials. Also, don't forget to pay a visit periodically to the Benefits Auctions.
You're going to have to ask Raymond W. from Trenton why he thinks I should be beat about the shoulders with a hardened carbon steel carving tool. It was all his idea. For his latest twist on this joke, click on the photo.
